跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Sony Ericsson K750i LCD Screen Replacement
你所需要的
  1. Sony Ericsson K750i LCD Screen Replacement, Battery Cover: 步骤 1 中的图像 1,1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i LCD Screen Replacement, Back Casing: 步骤 2 中的图像 1,1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i LCD Screen Replacement, Keypad: 步骤 5 中的图像 1,1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i LCD Screen Replacement: 步骤 7 中的图像 1,2 Sony Ericsson K750i LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 1,1
    • Remove the screws holding the screen in place.
  9. Sony Ericsson K750i LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Gently lift the base of the keypad to remove it.
  10. Sony Ericsson K750i LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Gently pull up the green film, avoiding the joystick.
    • The LCD screen will be attached to this film and come off with it.
结论
另外一个人完成了本指南。
Abby Evers
于10/04/11注册
202 声望
创作了6篇指南
团队
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S1G6
4 名成员
创作了12篇指南
一条评论
Works perfectly, thank you guys!
Aurelien - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 4,039
