当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the battery cover.
Press down firmly with your thumb and slide the cover back.
Remove two Phillips #0 screws from the battery chamber.
Remove two Torx T6 screws from the battery chamber.
Gently pry off the back casing.
Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
Remove the casing to expose the camera's components.
Gently pry open the front casing by working an opening tool along the entire seam.
Remove the front casing by gently lifting it from the phone.
Be careful not to pull off any other delicate pieces.
Remove the keypad.
The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
Remove the screws holding the screen in place.
Gently lift the base of the keypad to remove it.
Gently pull up the green film, avoiding the joystick.
The LCD screen will be attached to this film and come off with it.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于10/04/11注册
202 声望
创作了6篇指南
徽章: 12
+ 9更多徽章
UWSTOUT-ZHOU-F11S1G6
4 名成员
创作了12篇指南
Works perfectly, thank you guys!
Aurelien - 2014年8月26日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 4,039
