跳转到主内容
Sony DualSense Controller Touchpad Replacement
你所需要的
  1. Sony DualSense Controller Touchpad Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 2,2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Touchpad Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 1,3 Sony DualSense Controller Touchpad Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 2,3 Sony DualSense Controller Touchpad Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 3,3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Touchpad Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 2,2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Touchpad Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 1,3 Sony DualSense Controller Touchpad Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 2,3 Sony DualSense Controller Touchpad Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 3,3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Touchpad Replacement, Remove the middle trim: 步骤 5 中的图像 1,3 Sony DualSense Controller Touchpad Replacement, Remove the middle trim: 步骤 5 中的图像 2,3 Sony DualSense Controller Touchpad Replacement, Remove the middle trim: 步骤 5 中的图像 3,3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Touchpad Replacement, Remove the L1 button: 步骤 6 中的图像 1,3 Sony DualSense Controller Touchpad Replacement, Remove the L1 button: 步骤 6 中的图像 2,3 Sony DualSense Controller Touchpad Replacement, Remove the L1 button: 步骤 6 中的图像 3,3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. Sony DualSense Controller Touchpad Replacement, Remove the R1 button: 步骤 7 中的图像 1,3 Sony DualSense Controller Touchpad Replacement, Remove the R1 button: 步骤 7 中的图像 2,3 Sony DualSense Controller Touchpad Replacement, Remove the R1 button: 步骤 7 中的图像 3,3
    • Repeat the previous step to remove the R1 button.
  8. Sony DualSense Controller Touchpad Replacement, Remove the rear case screws: 步骤 8 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Remove the rear case screws: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Touchpad Replacement: 步骤 9 中的图像 1,2 Sony DualSense Controller Touchpad Replacement: 步骤 9 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Touchpad Replacement, Separate the rear case: 步骤 10 中的图像 1,3 Sony DualSense Controller Touchpad Replacement, Separate the rear case: 步骤 10 中的图像 2,3 Sony DualSense Controller Touchpad Replacement, Separate the rear case: 步骤 10 中的图像 3,3
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. Sony DualSense Controller Touchpad Replacement: 步骤 11 中的图像 1,3 Sony DualSense Controller Touchpad Replacement: 步骤 11 中的图像 2,3 Sony DualSense Controller Touchpad Replacement: 步骤 11 中的图像 3,3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. Sony DualSense Controller Touchpad Replacement: 步骤 12 中的图像 1,3 Sony DualSense Controller Touchpad Replacement: 步骤 12 中的图像 2,3 Sony DualSense Controller Touchpad Replacement: 步骤 12 中的图像 3,3
    • Repeat the previous step on the right edge to release its clips.
  13. Sony DualSense Controller Touchpad Replacement: 步骤 13 中的图像 1,2 Sony DualSense Controller Touchpad Replacement: 步骤 13 中的图像 2,2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. Sony DualSense Controller Touchpad Replacement, Remove the rear case: 步骤 14 中的图像 1,1
    • Remove the rear case.
  15. Sony DualSense Controller Touchpad Replacement, Disconnect the battery: 步骤 15 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Disconnect the battery: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
  16. Sony DualSense Controller Touchpad Replacement, Remove the battery: 步骤 16 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Remove the battery: 步骤 16 中的图像 2,2
    • Lift the battery straight out of the battery bracket.
  17. Sony DualSense Controller Touchpad Replacement, Remove the lower microphone: 步骤 17 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Remove the lower microphone: 步骤 17 中的图像 2,2
    在这个步骤中使用的工具:
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  18. Sony DualSense Controller Touchpad Replacement, Remove the battery bracket: 步骤 18 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Remove the battery bracket: 步骤 18 中的图像 2,2
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  19. Sony DualSense Controller Touchpad Replacement: 步骤 19 中的图像 1,2 Sony DualSense Controller Touchpad Replacement: 步骤 19 中的图像 2,2
    • Lift the battery bracket out of the motherboard.
  20. Sony DualSense Controller Touchpad Replacement, Disconnect the right trigger assembly: 步骤 20 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Disconnect the right trigger assembly: 步骤 20 中的图像 2,2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
  21. Sony DualSense Controller Touchpad Replacement: 步骤 21 中的图像 1,2 Sony DualSense Controller Touchpad Replacement: 步骤 21 中的图像 2,2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  22. Sony DualSense Controller Touchpad Replacement, Disconnect the left trigger assembly: 步骤 22 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Disconnect the left trigger assembly: 步骤 22 中的图像 2,2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  23. Sony DualSense Controller Touchpad Replacement: 步骤 23 中的图像 1,2 Sony DualSense Controller Touchpad Replacement: 步骤 23 中的图像 2,2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  24. Sony DualSense Controller Touchpad Replacement, Disconnect the upper microphone: 步骤 24 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Disconnect the upper microphone: 步骤 24 中的图像 2,2
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
  25. Sony DualSense Controller Touchpad Replacement, Disconnect the touchpad: 步骤 25 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Disconnect the touchpad: 步骤 25 中的图像 2,2
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  26. Sony DualSense Controller Touchpad Replacement, Lift out the motherboard: 步骤 26 中的图像 1,3 Sony DualSense Controller Touchpad Replacement, Lift out the motherboard: 步骤 26 中的图像 2,3 Sony DualSense Controller Touchpad Replacement, Lift out the motherboard: 步骤 26 中的图像 3,3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
  27. Sony DualSense Controller Touchpad Replacement, Remove the light guide: 步骤 27 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Remove the light guide: 步骤 27 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
  28. Sony DualSense Controller Touchpad Replacement: 步骤 28 中的图像 1,2 Sony DualSense Controller Touchpad Replacement: 步骤 28 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to remove the light guide bracket.
  29. Sony DualSense Controller Touchpad Replacement: 步骤 29 中的图像 1,2 Sony DualSense Controller Touchpad Replacement: 步骤 29 中的图像 2,2
    • Use a pair of tweezers or your fingers to remove the light guide.
  30. Sony DualSense Controller Touchpad Replacement, Remove the speaker: 步骤 30 中的图像 1,3 Sony DualSense Controller Touchpad Replacement, Remove the speaker: 步骤 30 中的图像 2,3 Sony DualSense Controller Touchpad Replacement, Remove the speaker: 步骤 30 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the speaker from the midframe.
    • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
  31. Sony DualSense Controller Touchpad Replacement, Remove the midframe: 步骤 31 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Remove the midframe: 步骤 31 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
  32. Sony DualSense Controller Touchpad Replacement: 步骤 32 中的图像 1,3 Sony DualSense Controller Touchpad Replacement: 步骤 32 中的图像 2,3 Sony DualSense Controller Touchpad Replacement: 步骤 32 中的图像 3,3
    • Carefully lift the midframe and motherboard up and out of the front case.
    • Be careful not to strain the vibrator motor wires.
    • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
  33. Sony DualSense Controller Touchpad Replacement, Remove the touchpad: 步骤 33 中的图像 1,2 Sony DualSense Controller Touchpad Replacement, Remove the touchpad: 步骤 33 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the touchpad bracket to the touchpad.
  34. Sony DualSense Controller Touchpad Replacement: 步骤 34 中的图像 1,3 Sony DualSense Controller Touchpad Replacement: 步骤 34 中的图像 2,3 Sony DualSense Controller Touchpad Replacement: 步骤 34 中的图像 3,3
    • Lift the touchpad bracket straight up off the front case.
    • Feed the ribbon cable back through the rectangular slot in the bracket during reassembly.
  35. Sony DualSense Controller Touchpad Replacement: 步骤 35 中的图像 1,1
    • Lift the front case up off of the touchpad.
结论
12等其他人完成本指南。
Sam Omiotek
于02/25/19注册
92,592 声望
创作了290篇指南
12指南评论
New touch won’t work with motherboard
Manson Knowz - 回复
Can you elaborate? I’m looking to buy one of these for this repair, and not sure which, or where
Gregg Cerenzio -
Hii, first of all big fan but i am havinf trouble finding the touchpad motherboard online to replace mine like i am talking about the whole unit cus the ribbon that is atach to mine i glued on and cant replase the ribbon so if you guys can help me find it would be a big help thx
patrick yard - 回复
Did you found a replacement part? I'm looking for the same thing
Julian Giraldo -
if I'm understanding correctly, you can use a hair dryer to heat up the touchpad and melt the adhesive that holds it to the board. Then do the reverse to the new touch pad.
Hope this helps!
LoudmouthdSHNK -
添加评论
浏览统计数据:
过去 24 小时: 29
过去 7 天: 298
过去 30 天: 1,395
总计 54,587
