跳转到主内容
Sony DualSense Controller Middle Trim Replacement
你所需要的
  1. Sony DualSense Controller Middle Trim Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 1,2 Sony DualSense Controller Middle Trim Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 2,2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 1,3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 2,3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 3,3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Middle Trim Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 1,2 Sony DualSense Controller Middle Trim Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 2,2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 1,3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 2,3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 3,3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: 步骤 5 中的图像 1,3 Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: 步骤 5 中的图像 2,3 Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: 步骤 5 中的图像 3,3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
结论
7等其他人完成本指南。
Sam Omiotek
于02/25/19注册
88,212 声望
创作了290篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 80
过去 30 天: 388
总计 12,250
