跳转到主内容
Sony DualSense Controller Light Guide Replacement
你所需要的
  1. Sony DualSense Controller Light Guide Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 2,2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Light Guide Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 1,3 Sony DualSense Controller Light Guide Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 2,3 Sony DualSense Controller Light Guide Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 3,3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Light Guide Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 2,2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Light Guide Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 1,3 Sony DualSense Controller Light Guide Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 2,3 Sony DualSense Controller Light Guide Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 3,3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Light Guide Replacement, Remove the middle trim: 步骤 5 中的图像 1,3 Sony DualSense Controller Light Guide Replacement, Remove the middle trim: 步骤 5 中的图像 2,3 Sony DualSense Controller Light Guide Replacement, Remove the middle trim: 步骤 5 中的图像 3,3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Light Guide Replacement, Remove the L1 button: 步骤 6 中的图像 1,3 Sony DualSense Controller Light Guide Replacement, Remove the L1 button: 步骤 6 中的图像 2,3 Sony DualSense Controller Light Guide Replacement, Remove the L1 button: 步骤 6 中的图像 3,3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
    Tried prying from the front of the buttons as pictured and my spudger broke off in the gap. A video I watched showed them being pried off from the back (between the R1/R2 and L1/L2 buttons) which seemed much easier.
    Lora Singleton - 回复
    Agree with Lora's comment above. I was able to use an old credit card to take L1/R1 out this way. I pressed down the L2/R2 button to create space to work in, then came in from between L1/L2 and R1/R2. It's easy to pop one of the outer corners first then you can work the credit card around the top and the rest falls out.
    darkstar448 - 回复
    Man, if I'd just read the thumb part...
    caldugen - 回复
  7. Sony DualSense Controller Light Guide Replacement, Remove the R1 button: 步骤 7 中的图像 1,3 Sony DualSense Controller Light Guide Replacement, Remove the R1 button: 步骤 7 中的图像 2,3 Sony DualSense Controller Light Guide Replacement, Remove the R1 button: 步骤 7 中的图像 3,3
    • Repeat the previous step to remove the R1 button.
    to save a few bucks, the L1 and R1 buttons can be removed without the use of the spudger tool by using any thin prying tool and just pry the buttons from the bottom instead of the top
    Alan Peng - 回复
    What I didn't see addressed anywhere (here or in other similar articles) is that replacement R1 / L1 buttons can be differ enough to be un-usable depending on which model your ps5 controller is. The ones I ordered don't fit and now I can't find a way to be sure I get the right ones because few know there's even a difference.
    Walt Mather - 回复
    Did you already figured it out? The version the we need yo use?, We are in the same situation here.
    Gerald Ross Rodriguez -
    Lora Singleton - 回复
  8. Sony DualSense Controller Light Guide Replacement, Remove the rear case screws: 步骤 8 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Remove the rear case screws: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Light Guide Replacement: 步骤 9 中的图像 1,2 Sony DualSense Controller Light Guide Replacement: 步骤 9 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Light Guide Replacement, Separate the rear case: 步骤 10 中的图像 1,3 Sony DualSense Controller Light Guide Replacement, Separate the rear case: 步骤 10 中的图像 2,3 Sony DualSense Controller Light Guide Replacement, Separate the rear case: 步骤 10 中的图像 3,3
    • Be gently when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. Sony DualSense Controller Light Guide Replacement: 步骤 11 中的图像 1,3 Sony DualSense Controller Light Guide Replacement: 步骤 11 中的图像 2,3 Sony DualSense Controller Light Guide Replacement: 步骤 11 中的图像 3,3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. Sony DualSense Controller Light Guide Replacement: 步骤 12 中的图像 1,3 Sony DualSense Controller Light Guide Replacement: 步骤 12 中的图像 2,3 Sony DualSense Controller Light Guide Replacement: 步骤 12 中的图像 3,3
    • Repeat the previous step on the right edge to release its clips.
  13. Sony DualSense Controller Light Guide Replacement: 步骤 13 中的图像 1,2 Sony DualSense Controller Light Guide Replacement: 步骤 13 中的图像 2,2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. Sony DualSense Controller Light Guide Replacement, Remove the rear case: 步骤 14 中的图像 1,1
    • Remove the rear case.
    There are four more clips/hooks hidden in the seams along the outer sides of the handles. If you pull open the controller as shown in this step, then you will shear off the two tiny clips which are right next to the R1 and L1 buttons.
    Therefore, you should first release those clips by prying the seams open sideways.
    I noticed this with the updated design of the controller, not sure whether the hooks are present on the first version.
    The hooks are not critical for the integrity of the controller as the two halves are held together by the screws hidden under the buttons. The damage does show that the controller has been taken apart.
    Nick - 回复
    Thought I'd clarify: The clips next to the L1 and R1 are on the outer side from the L1 and R1 buttons, I'd suggest zooming in on the picture to see them. They're quite easy to break, but also easy to remove using the plastic spudger along the seam, bending the bottom cover outwards
    Franz Rolfsvaag -
    I am still strugling to find the clips. Could someone point them out in the image with a screen shot or something like that.
    aGingerThing - 回复
    I keep getting stuck at this step too with the new DualSense CFI-ZCT1WA revision. The top and bottom shells seem like they are fused together next to L1/R1 but I can't seem to be able to find where these hidden clips are located. My controller is still in warranty so I don't want to break them in case I can't fix my issue.
    I tried this but it seems that the you need a lot of force and I ended up bending the tip of my spudger. Are you sure it's not the top cover that you need to pry away? The bottom cover has a ridge to make sure it's under the top cover so it's not easy to bend outwards.
    @samomio I think there needs to be a step added for these new clips.
    robplease - 回复
    Ok, not seeing a lot of motion on this request, so I've uploaded photos of the hooks to imgur.
    Here ya go: https://imgur.io/a/7NWmQi5
    Sean Murphy - 回复
    Life save Sean. Appreciate the image.
    Vili - 回复
    This guide really needs an update on this. I had a really hard time getting the forward clips to release even after referring to the comments above. Pretty sure I broke them in the end. No big deal but would be great if the iFixit experts could work out a good method for releasing them.
    Marcus Harvey - 回复
    I finally figure it out!!
    The hidden clip is very tricky but once you understand how it works it is easy to remove.
    Use Sean's picture: https://imgur.io/a/7NWmQi5
    What sean is showing, is actually the bottom shell of the seam.
    To disassemble
    1. Use the flat side of the spudger, pry the bottom seam OUTWARDS near the R1/L1 button hole.
    2. (most important) While prying the bottom shell seam outwards, push your thumb on the upper shell and push outward as well (you can do this by applying pressure from the removed R1/L1 button hole towards the seam. And then it will disassemble automatically
    And that's it!
    Penn - 回复
    updated instruction:
    To disassemble
    2. (most important) While prying the bottom shell seam outwards, hold your thumb on the upper shell as anchor and then use your other finger to pry the bottom edge of the controller up away from the shell. If you are doing the first step, then don't worry about breaking the clip, just force it open. And then it will disassemble automatically
    And that's it!
    Penn - 回复
    Yes! Thanks a bunch Penn. That did the trick! Much appreciated
    Sean -
    I managed to do it just by pulling harder than what I was already doing. And I don't think I broke anything. So, for me at least, the technique described in this guide worked.
    Riedweg Guillaume - 回复
    The video linked below clearly shows how to open the controllers with the extra clips near the L1/R1 areas.
    See a video here by How To X on YouTube... https://youtu.be/djIvRoclr_E?si=dKFpQCZe...
    Jason Z - 回复
    I really struggled with releasing the rest of the back panel (close to the shoulder buttons.) What finally seemed to do the trick for me, was doing both sides at once with upward turning motion of the back panel with the shoulder buttons approximately at the axis. Trying to release just one side and then the other felt impossible without potentially breaking the case.
    dborba - 回复
    This was what did it for me
    Matthew Williamson -
  15. Sony DualSense Controller Light Guide Replacement, Disconnect the battery: 步骤 15 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Disconnect the battery: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
    Tweezers aren't gonna grip that the way you need.
    Leif DeWolf - 回复
    For those having trouble using tweezers to pull out the connector, you can grab below the lip of the connector and use the controller as a lever to pull it up as seen here DualSense Controller v2 Battery Replacement
    This little trick helped me so much and I believe it should be shown on this guide as well.
    Ezra Worthington - 回复
    Tweezers is too weak for this. I use my finger nails after removing the battery from the slot, straighten the cable lines and slowly wiggle it out.
    Penn - 回复
  16. Sony DualSense Controller Light Guide Replacement, Remove the battery: 步骤 16 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Remove the battery: 步骤 16 中的图像 2,2
    • Lift the battery straight out of the battery bracket.
  17. Sony DualSense Controller Light Guide Replacement, Remove the lower microphone: 步骤 17 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Remove the lower microphone: 步骤 17 中的图像 2,2
    在这个步骤中使用的工具:
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
    These ribbon cables have small tabs on either side you can use to help pull out the cable. You can slightly pull up, alternating between the two sides, to slowly wiggle the connector out.
    Tran Anh Nguyen - 回复
    Might be a rookie mistake, but DO NOT REMOVE THE WHITE BRACKETS, only the ribbon! If you do, you’ll have an awful time putting it back and will most likely mess it up. Yes I did.
    Joris D - 回复
    I tried to use metal tweezers to pull this out and absolutely shredded the ribbon in the process. It's just a microphone so I wouldn't expect it to matter but now none of the games get any input from the controller even though the controller works fine in the home menu 🥲
    Probably just use your fingers if you have the dexterity for it.
    Grey - 回复
    As others have said, try to only remove the ribbon and not the white connector. I'd advise holding down the white connector with something (perhaps your prying tool or finger) as you pull the ribbon out gently with the tweezers.
    Best to avoid pulling out the white connector if possible - but its not the end of the world if you do accidentally pull it out, as I did. You can put the connector back in but you need to be very precise with the alignment over the 6 pins it connects to on the circuit board. I had to use a magnifying glass and it took me a few attempts.
    Fruke - 回复
  18. Sony DualSense Controller Light Guide Replacement, Remove the battery bracket: 步骤 18 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Remove the battery bracket: 步骤 18 中的图像 2,2
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  19. Sony DualSense Controller Light Guide Replacement: 步骤 19 中的图像 1,2 Sony DualSense Controller Light Guide Replacement: 步骤 19 中的图像 2,2
    • Lift the battery bracket out of the motherboard.
    Black and red wires fit neatly under the lower left and lower right arms of the battery bracket, to avoid potential damage when reconnecting the rear case.
    Seomhnasaigh B - 回复
    This needs to be noted. Thanks!
    Nick Gatti -
  20. Sony DualSense Controller Light Guide Replacement, Disconnect the right trigger assembly: 步骤 20 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Disconnect the right trigger assembly: 步骤 20 中的图像 2,2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
    If your cables are blue and in a different position, don't sweat. It's all good. Just do the same as they do and if you feel it is necessary, label with a sharpie left and right on each cable. A simple L and R works for this case
    Qbert 2030 - 回复
  21. Sony DualSense Controller Light Guide Replacement: 步骤 21 中的图像 1,2 Sony DualSense Controller Light Guide Replacement: 步骤 21 中的图像 2,2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
    Depending on the revision of your controller, these ribbon cables may be slim and white and if you remove it completely, you might have to remove and tear down the trigger assembly to get the ribbon cable back in.
    Robert Borrero - 回复
    maybe I'm missing something but in this case it doesn't seem to me like these cables need to be outright removed.
    TheHooligan95 - 回复
  22. Sony DualSense Controller Light Guide Replacement, Disconnect the left trigger assembly: 步骤 22 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Disconnect the left trigger assembly: 步骤 22 中的图像 2,2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  23. Sony DualSense Controller Light Guide Replacement: 步骤 23 中的图像 1,2 Sony DualSense Controller Light Guide Replacement: 步骤 23 中的图像 2,2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  24. Sony DualSense Controller Light Guide Replacement, Disconnect the upper microphone: 步骤 24 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Disconnect the upper microphone: 步骤 24 中的图像 2,2
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
    what is the white thing soldered to the motherboard called where the mic ribbon cable plugs and where can i find the part?
    Abhi K - 回复
    @abhik13943 did you ever find this part?
    DaMej2895 - 回复
    unfortunately, no. i'm just using my controller without a mic.
    Abhi K -
  25. Sony DualSense Controller Light Guide Replacement, Disconnect the touchpad: 步骤 25 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Disconnect the touchpad: 步骤 25 中的图像 2,2
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  26. Sony DualSense Controller Light Guide Replacement, Lift out the motherboard: 步骤 26 中的图像 1,3 Sony DualSense Controller Light Guide Replacement, Lift out the motherboard: 步骤 26 中的图像 2,3 Sony DualSense Controller Light Guide Replacement, Lift out the motherboard: 步骤 26 中的图像 3,3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
    Pushing on the joysticks makes this much easier.
    zidek22 - 回复
    My motherboard wouldn't just lift right out. So I noticed there's also a pair of barely visible small black clips, one on each side of the motherboard, holding it down. One is right beside the battery connector and the other's directly across on the opposite side of the motherboard right beside the ribbon cable connector.
    Jason Mulholland - 回复
    Such a good observation!
    zidek22 -
    That helped a lot. If you can push those tabs it comes out a lot easier. I used my tweezers to push the left one and then as others had said pushing on the joysticks from the front of the controller makes it much easier.
    Fruke -
    Just push on the sticks. Pops out like a charm, zero effort.
    Italian Retro Guy - 回复
  27. Sony DualSense Controller Light Guide Replacement, Remove the light guide: 步骤 27 中的图像 1,2 Sony DualSense Controller Light Guide Replacement, Remove the light guide: 步骤 27 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
    Mine didn't have this piece
    John - 回复
  28. Sony DualSense Controller Light Guide Replacement: 步骤 28 中的图像 1,2 Sony DualSense Controller Light Guide Replacement: 步骤 28 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to remove the light guide bracket.
  29. Sony DualSense Controller Light Guide Replacement: 步骤 29 中的图像 1,2 Sony DualSense Controller Light Guide Replacement: 步骤 29 中的图像 2,2
    • Use a pair of tweezers or your fingers to remove the light guide.
    Where do i buy a new light guide?
    Jasper Nuyts - 回复
结论
另外一个人完成了本指南。
Sam Omiotek
于02/25/19注册
83,736 声望
创作了290篇指南
2条评论
what do i need to do if player indicator white light doesn't work? please help i can't find any guide on the internet
Avt - 回复
I have the same problem. Did you find a fix?
Clayerhd -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 28
过去 30 天: 130
总计 5,990
