本指南有最近更改,您可查看未经巡查的最新版本。
简介
Some things to consider before you work on the Sony Cyber-shot DSC W800 to replace the Lens:
- The Lens is an integral part of the device and any improper handling can cause issues in other parts of the camera.
- Be cautious when removing ribbon wires.
- Be sure to keep track of all pieces that are taken apart.
你所需要的
Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
3等其他人完成本指南。
