当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Using a flat head screw driver gently pry up on the tab securing the larger ribbon cable which connects the display screen and camera sensor / battery housing.
Remove the ribbon cable connecting the LCD display and camera sensor / battery housing.
Following the same procedure, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
这个步骤还没有翻译 帮忙翻译一下
Now turn your attention to the camera sensor and battery housing. Identify the two connection points of the large ribbon cable.
Carefully place a flathead screwdriver under the left ribbon cable connection point and pull up to disconnect.
Repeat the previous step but this time carefully remove the right ribbon cable connection point.
After both sides of the ribbon cable have been disconnected it is ready to be replaced.
另外一个人完成了本指南。
一条评论
The locking meachanism on the Monitors ribbon cable is broken on my camera.
It pivots and locks the ribbon down to create a secure connection. However, because of the Brocken lock one side is not locked down therefore the Monitor turns off when tapped.
Is there a place that I could get a replacement for this lock?
much appreciated.
