简介
This guide will help you to replace the lens assembly on the Sony Cyber Shot DSC-W170.
If the camera lens is cracked or otherwise damaged, the solution is to replace the camera lens.
Be careful when removing shattered glass displays, be sure to remove power/disconnect batteries ,and take a look at the ESD-safe tools website before performing this task!
A necessary skill is to be able to use a soldering iron.
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
你所需要的
Desolder the wires connecting the top panel circuit board from the lens with the soldering iron.
