跳转到主内容
Sony BDP-s7200 Motherboard Replacement
你所需要的
  1. Sony BDP-s7200  Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200  Motherboard Replacement: 步骤 2 中的图像 1,2 Sony BDP-s7200  Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200  Motherboard Replacement: 步骤 3 中的图像 1,2 Sony BDP-s7200  Motherboard Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200  Motherboard Replacement: 步骤 4 中的图像 1,1
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: 步骤 5 中的图像 1,3 Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: 步骤 5 中的图像 2,3 Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: 步骤 5 中的图像 3,3
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200  Motherboard Replacement: 步骤 6 中的图像 1,2 Sony BDP-s7200  Motherboard Replacement: 步骤 6 中的图像 2,2
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200  Motherboard Replacement: 步骤 7 中的图像 1,3 Sony BDP-s7200  Motherboard Replacement: 步骤 7 中的图像 2,3 Sony BDP-s7200  Motherboard Replacement: 步骤 7 中的图像 3,3
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200  Motherboard Replacement: 步骤 8 中的图像 1,2 Sony BDP-s7200  Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
  9. Sony BDP-s7200  Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 Sony BDP-s7200  Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Remove the ribbon cables connected to the front panel board.
    • Pull firmly, but not too hard as to not damage the ribbon cable.
  10. Sony BDP-s7200  Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the cable connected to the power supply.
  11. Sony BDP-s7200  Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the ribbon cables that connect the motherboard to the disk drive.
    • Pull firmly, but not too hard as to not damage the ribbon cables.
  12. Sony BDP-s7200  Motherboard Replacement: 步骤 12 中的图像 1,3 Sony BDP-s7200  Motherboard Replacement: 步骤 12 中的图像 2,3 Sony BDP-s7200  Motherboard Replacement: 步骤 12 中的图像 3,3
    • Remove the three screws using the Phillips #2 Screwdriver.
    • Do not attempt to remove. There is one additional screw on the back of the device.
    • Remove the screw on the back of the device with the same screwdriver.
  13. Sony BDP-s7200  Motherboard Replacement: 步骤 13 中的图像 1,2 Sony BDP-s7200  Motherboard Replacement: 步骤 13 中的图像 2,2
    • Lift the motherboard from the front and carefully pull it out.
    • There is a small square adhesive on the bottom. Leave it there for reassembly.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 420
