跳转到主内容
Sony BDP-S3500 Wi-Fi Module Replacement
你所需要的
  1. Sony BDP-S3500 Wi-Fi Module Replacement, Front Panel: 步骤 1 中的图像 1,2 Sony BDP-S3500 Wi-Fi Module Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Wi-Fi Module Replacement: 步骤 2 中的图像 1,1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Wi-Fi Module Replacement: 步骤 3 中的图像 1,2 Sony BDP-S3500 Wi-Fi Module Replacement: 步骤 3 中的图像 2,2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Wi-Fi Module Replacement, Port Board: 步骤 4 中的图像 1,2 Sony BDP-S3500 Wi-Fi Module Replacement, Port Board: 步骤 4 中的图像 2,2
    • Keep the back side up and facing towards you.
    • Carefully disconnect the blue ribbon connecting the port board and motherboard.
    • Be delicate while removing the ribbon.
  5. Sony BDP-S3500 Wi-Fi Module Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
  6. Sony BDP-S3500 Wi-Fi Module Replacement: 步骤 6 中的图像 1,1
    • Remove the port board from the device.
  7. Sony BDP-S3500 Wi-Fi Module Replacement, Wi-Fi Module: 步骤 7 中的图像 1,1
    • Remove the white ribbon cable connecting the Wi-Fi module to the motherboard by gently pulling it out.
  8. Sony BDP-S3500 Wi-Fi Module Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the 7mm screw from the Wi-Fi module.
  9. Sony BDP-S3500 Wi-Fi Module Replacement: 步骤 9 中的图像 1,1
    • The Wi-Fi module can now be safely removed.
结论
Bushra Banuso
于01/22/20注册
97 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 391
