简介
Before following this guide refer to the troubleshooting guide to make sure this is the right guide to fix your device.
Use this guide to replace the motherboard within a Sony BDP-S3500. The motherboard controls every process within the device. The motherboard could be broken because of a power surge or physical damage. This component should be one of the last components one should replace after all other attempted fixes failed.
Before beginning this guide, make sure the device is turned off and completely unplugged from all external sources.
你所需要的
Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
Remove the three ribbon cables by gently pulling the cables out of each connector.
Remove the ribbon cables by holding onto the cable and gently pulling straight up.
另外一个人完成了本指南。
