跳转到主内容
Sony BDP-S3500 Disk Drive Replacement
你所需要的
  1. Sony BDP-S3500 Disk Drive Replacement, Front Panel: 步骤 1 中的图像 1,2 Sony BDP-S3500 Disk Drive Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Disk Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Disk Drive Replacement: 步骤 3 中的图像 1,2 Sony BDP-S3500 Disk Drive Replacement: 步骤 3 中的图像 2,2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Disk Drive Replacement, Disk Drive: 步骤 4 中的图像 1,2 Sony BDP-S3500 Disk Drive Replacement, Disk Drive: 步骤 4 中的图像 2,2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Disk Drive Replacement: 步骤 5 中的图像 1,2 Sony BDP-S3500 Disk Drive Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Disk Drive Replacement: 步骤 6 中的图像 1,2 Sony BDP-S3500 Disk Drive Replacement: 步骤 6 中的图像 2,2
    • Carefully lift and slide the disk drive out of the casing.
结论
V W
于01/22/20注册
197 声望
撰写一个指南
团队
一条评论
Hello, great guide thank you. How do you go about finding the correct replacement drive?
Andy Day - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 394
