跳转到主内容
Sony BDP-BX510 Wi-Fi Module Replacement
你所需要的
  1. Sony BDP-BX510 Wi-Fi Module Replacement, Outer Cover: 步骤 1 中的图像 1,1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 2 中的图像 1,2 Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 2 中的图像 2,2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 3 中的图像 1,2 Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 3 中的图像 2,2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 4 中的图像 1,3 Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 4 中的图像 2,3 Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 4 中的图像 3,3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 5 中的图像 1,1
    • Slide the cover forward to remove.
  6. Sony BDP-BX510 Wi-Fi Module Replacement, Port Board: 步骤 6 中的图像 1,1
    • Find the large ribbon cable that connects the port board to the motherboard.
    • Carefully pull directly upwards to disconnect the cable.
  7. Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the 5mm screwdriver attached to the port board.
  8. Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 8 中的图像 1,1
    • Unclip the metal piece on the lower right corner by gently lifting it up.
  9. Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 9 中的图像 1,1
    • Remove the port board by simply pulling it away from the device.
  10. Sony BDP-BX510 Wi-Fi Module Replacement, Wi-Fi Module: 步骤 10 中的图像 1,1
    • Pull the cable that attaches the Wi-Fi module to the motherboard.
    • The cable will be hard to remove, so pull hard but carefully.
  11. Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 11 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the single 5mm screw that holds Wi-Fi module to the device.
  12. Sony BDP-BX510 Wi-Fi Module Replacement: 步骤 12 中的图像 1,1
    • Carefully remove the Wi-Fi module from the device.
    • Avoid getting fingerprints on the module.
结论
Niki Ngosi
于01/19/20注册
375 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 297
