跳转到主内容
Sony Alpha 5100 LCD Replacement
你所需要的
  1. Sony Alpha 5100 LCD Replacement, LCD: 步骤 1 中的图像 1,1
    • Slide the power switch on the top of the camera to "off."
  2. Sony Alpha 5100 LCD Replacement: 步骤 2 中的图像 1,1
    • Flip the LCD screen so that you have access to the back of the screen. The front of the screen should be facing the direction that the lens is facing.
  3. Sony Alpha 5100 LCD Replacement: 步骤 3 中的图像 1,2 Sony Alpha 5100 LCD Replacement: 步骤 3 中的图像 2,2
    • Remove the two 2mm Phillips #00 screws on the back of the screen.
    • Remove the two 2mm Phillips #00 screws on the top of the LCD screen.
  4. Sony Alpha 5100 LCD Replacement: 步骤 4 中的图像 1,1
    • Carefully pry open the back plate off the screen with an iFixit opening tool.
    • If separating the plates is giving you trouble, aim for the notch at the bottom of the plate.
  5. Sony Alpha 5100 LCD Replacement: 步骤 5 中的图像 1,2 Sony Alpha 5100 LCD Replacement: 步骤 5 中的图像 2,2
    • Carefully open the back plate of the screen.
结论
3等其他人完成本指南。
Kevin Raggiani
于10/30/19注册
444 声望
创作了3篇指南
团队
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 UMass Dartmouth, Team S4-G6, Saloman Fall 2019 的会员
UMASSD-SALOMAN-F19S4G6
3 名成员
创作了8篇指南
1指南评论
Hello, thank you for this but it’s only half the steps, how to remove the LCD and touch screen after step 5? Something else is holding it in place. Can lift the outer edge a little only. Possibly it is glue or tape? My touchscreen is always active and focus rectangle moving around the lower part of screen. Can touch screen and it will go there but soon moves back to lower area.
Thank you.
John Meldrum - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 56
总计 2,450
