跳转到主内容
Sony α6500 Lens Mount Replacement
你所需要的
  1. Sony α6500 Lens Mount Replacement, Lens Mount: 步骤 1 中的图像 1,2 Sony α6500 Lens Mount Replacement, Lens Mount: 步骤 1 中的图像 2,2
    • Use a screwdriver to remove four 5mm JIS 00 screws from the lens mount.
  2. Sony α6500 Lens Mount Replacement: 步骤 2 中的图像 1,2 Sony α6500 Lens Mount Replacement: 步骤 2 中的图像 2,2
    • Pull the lens mount off by gently wiggling it until it comes loose.
    • It is difficult to slide the mount off the metal pin sticking through the lower left side. Pull it off from where the pin is if it gets stuck.
  3. Sony α6500 Lens Mount Replacement: 步骤 3 中的图像 1,1
    • Remove the metal ring underneath the lens mount.
    • When replacing the ring, line up the two holes in the ring with the two pins on either side of the mount.
结论
2等其他人完成本指南。
Jackson Furie
于10/10/19注册
807 声望
创作了5篇指南
团队
Cal Poly, Team S11-G5, Regan Fall 2019 Cal Poly, Team S11-G5, Regan Fall 2019 的会员
CPSU-REGAN-F19S11G5
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 970
