跳转到主内容
Sonos Playbase A Speaker from the Main Array Replacement
你所需要的
  1. Sonos Playbase A Speaker from the Main Array Replacement, Bottom Panel: 步骤 1 中的图像 1,3 Sonos Playbase A Speaker from the Main Array Replacement, Bottom Panel: 步骤 1 中的图像 2,3 Sonos Playbase A Speaker from the Main Array Replacement, Bottom Panel: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase A Speaker from the Main Array Replacement: 步骤 2 中的图像 1,2 Sonos Playbase A Speaker from the Main Array Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase A Speaker from the Main Array Replacement: 步骤 3 中的图像 1,2 Sonos Playbase A Speaker from the Main Array Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase A Speaker from the Main Array Replacement, Main Speaker Array: 步骤 4 中的图像 1,2 Sonos Playbase A Speaker from the Main Array Replacement, Main Speaker Array: 步骤 4 中的图像 2,2
  5. Sonos Playbase A Speaker from the Main Array Replacement: 步骤 5 中的图像 1,2 Sonos Playbase A Speaker from the Main Array Replacement: 步骤 5 中的图像 2,2
    • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
    • See Recognizing & Disconnecting Cable Connectors for more information.
  6. Sonos Playbase A Speaker from the Main Array Replacement: 步骤 6 中的图像 1,3 Sonos Playbase A Speaker from the Main Array Replacement: 步骤 6 中的图像 2,3 Sonos Playbase A Speaker from the Main Array Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
  7. Sonos Playbase A Speaker from the Main Array Replacement: 步骤 7 中的图像 1,1
    • Remove the main speaker array by gripping it on both sides and pulling it out.
    • The array may require a significant amount of force to remove.
    • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
    • Do not to yank the array out too suddenly or too far as this may damage the device.
  8. Sonos Playbase A Speaker from the Main Array Replacement: 步骤 8 中的图像 1,1
    • Prop the removed main speaker array up on top of the main circuit board.
  9. Sonos Playbase A Speaker from the Main Array Replacement, Speaker from the Main Array: 步骤 9 中的图像 1,2 Sonos Playbase A Speaker from the Main Array Replacement, Speaker from the Main Array: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    Pro Tech Toolkit
    $74.95
    购买
    • Remove the four 11mm T-10 screws from the individual speaker that needs replacement, by turning the screws counterclockwise.
  10. Sonos Playbase A Speaker from the Main Array Replacement: 步骤 10 中的图像 1,1
    • Remove the damaged speaker from the array socket, by grasping the speaker with one hand, the array with your other and pulling outward.
  11. Sonos Playbase A Speaker from the Main Array Replacement: 步骤 11 中的图像 1,2 Sonos Playbase A Speaker from the Main Array Replacement: 步骤 11 中的图像 2,2
结论
George Slivka
于10/08/18注册
339 声望
创作了3篇指南
团队
Cal Poly, Team S17-G2, White Fall 2018 Cal Poly, Team S17-G2, White Fall 2018 的会员
CPSU-WHITE-F18S17G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 23
总计 2,427
