跳转到主内容
Skytex Skypad Alpha 2 Battery Replacement
你所需要的
  1. Skytex Skypad Alpha 2 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Battery Replacement: 步骤 2 中的图像 1,2 Skytex Skypad Alpha 2 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Battery Replacement: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Battery Replacement: 步骤 4 中的图像 1,1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Remove soldered connections to separate the battery wires from the motherboard.
    • Remove all black and yellow tape, if necessary, on motherboard.
    • Following the red and black wires, that come out of the battery, to their respective connections on the motherboard will indicate where to solder.
    • Follow link for further soldering information: How to Solder and Desolder Connections
  6. Skytex Skypad Alpha 2 Battery Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to remove battery from tablet.
    • Be sure to remove the battery carefully to avoid damage. Damage of battery can release harmful chemicals and may cause a fire.
结论
另外一个人完成了本指南。
Rebecca Ramirez
于09/23/15注册
481 声望
创作了3篇指南
团队
Baylor, Team 6-5, Williams Fall 2015 Baylor, Team 6-5, Williams Fall 2015 的会员
BU-WILLIAMS-F15S6G5
3 名成员
创作了8篇指南
一条评论
Excellent Guide
Problem is where to obtain the Replacement battery ???
J P SULLIVAN - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 799
