跳转到主内容
Skytex SP728 Screen Replacement
你所需要的
  1. Skytex SP728 Screen Replacement, Case: 步骤 1 中的图像 1,1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Screen Replacement: 步骤 2 中的图像 1,1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Screen Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Screen Replacement: 步骤 4 中的图像 1,1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Screen Replacement, Screen: 步骤 5 中的图像 1,3 Skytex SP728 Screen Replacement, Screen: 步骤 5 中的图像 2,3 Skytex SP728 Screen Replacement, Screen: 步骤 5 中的图像 3,3
    • Follow the Case Replacement to separate the tablet from its backing
    • Using a small Phillips screw driver, unscrew all screws connecting circuit board to device
    • Remove all tape connecting battery and circuit board to front case
    • Detach all connector strips from the circuit board
  6. Skytex SP728 Screen Replacement: 步骤 6 中的图像 1,2 Skytex SP728 Screen Replacement: 步骤 6 中的图像 2,2
    • Using the plastic opening tool, begin separating the front screen from the display
  7. Skytex SP728 Screen Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Once screen has been separated, use tweezers to remove front camera
结论
To reassemble your device with a new screen, follow these instructions in reverse order.
另外一个人完成了本指南。
团队
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 的会员
USFT-BROWN-W15S5G1
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 221
