跳转到主内容
Skytex SP728 Battery Replacement
你所需要的
  1. Skytex SP728 Battery  Replacement, Case: 步骤 1 中的图像 1,1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Battery  Replacement: 步骤 2 中的图像 1,1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Battery  Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Battery  Replacement: 步骤 4 中的图像 1,1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Battery  Replacement, Battery: 步骤 5 中的图像 1,1
    • Remove the yellow and black tape around the battery very carefully
  6. Skytex SP728 Battery  Replacement: 步骤 6 中的图像 1,2 Skytex SP728 Battery  Replacement: 步骤 6 中的图像 2,2
    • Use the soldering iron and remove soldered connections to separate the wires connected to the battery from the circuit board.
    • Follow the link below for additional soldering information 如何焊接和拆焊
    • Soldering uses heat so make sure you are careful while doing it. Also, excessive heat can damage the components. So do not apply the soldering iron on a component for extended periods of time.
  7. Skytex SP728 Battery  Replacement: 步骤 7 中的图像 1,1
    • Using the plastic opening tool, lift up the battery from right edge and set aside.
    • Make sure that you take the battery out very carefully without bending it or damaging it as it contains toxic chemicals.
    • While soldering the wires for the new battery, remember that the red wire has to be connected to the positive terminal and the black wire has to be connected to the negative terminal.
结论
To reassemble your device with a new battery, follow these instructions in reverse order.
另外一个人完成了本指南。
Galika Adhikari
于01/21/15注册
248 声望
创作了2篇指南
团队
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 的会员
USFT-BROWN-W15S5G1
4 名成员
创作了11篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 737
