跳转到主内容
Skullcandy UPROCK Earpiece Wiring Replacement
你所需要的
  1. Skullcandy UPROCK Earpiece Wiring Replacement, Earpiece Wiring: 步骤 1 中的图像 1,1
    • Remove the cushion from the ear piece.
  2. Skullcandy UPROCK Earpiece Wiring Replacement: 步骤 2 中的图像 1,2 Skullcandy UPROCK Earpiece Wiring Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 to unscrew three 3.4MM screws from the earpiece.
  3. Skullcandy UPROCK Earpiece Wiring Replacement: 步骤 3 中的图像 1,2 Skullcandy UPROCK Earpiece Wiring Replacement: 步骤 3 中的图像 2,2
    • Find the wires connected to the speaker and check if they are intact.
  4. Skullcandy UPROCK Earpiece Wiring Replacement: 步骤 4 中的图像 1,1
    • If a wire is broken, use a soldering iron to reattach it to the speaker.
    • To learn how to solder, read the 如何焊接和拆焊 Guide.
    • After soldering is complete, the wires should look like this.
终点
2等其他人完成本指南。
一条评论
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
Anuj Verma - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 23
总计 6,212
