跳转到主内容
Skullcandy Hesh 3 Speaker Replacement
你所需要的
  1. Skullcandy Hesh 3 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Skullcandy Hesh 3 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Skullcandy Hesh 3 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Start by removing the earmuffs on the speaker side with the charging port. Gently pull from any point of the ear cushion, while also holding on to the base of the speaker.
    • Use a Phillips #00 screwdriver to remove all four 4.0 mm screws securing the faceplate.
    • Lastly, remove the faceplate by gently lifting it without pulling off the wires that are attached to the faceplate.
  2. Skullcandy Hesh 3 Speaker Replacement: 步骤 2 中的图像 1,2 Skullcandy Hesh 3 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a soldering iron to detach the red wire (R+) and blue wire ( R) from the motherboard.
    • The soldering iron is very hot. Be careful when using it as it can burn skin, etc. Please refer to the How to Solder and Desolder Connection guide for more information on soldering.
    • R+ should be connected to the red wire and R should be connected to the blue wire.
  3. Skullcandy Hesh 3 Speaker Replacement: 步骤 3 中的图像 1,3 Skullcandy Hesh 3 Speaker Replacement: 步骤 3 中的图像 2,3 Skullcandy Hesh 3 Speaker Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Position the speaker so the inside is facing up.
    • Use a heat gun to warm the adhesive securing the speaker to the housing.
    • Aim the gun from a distance to prevent any damage to the plastic. Always keep the heat gun in motion while using it so one area doesn't melt.
    • Use tweezers to push the speaker through to remove it. Avoid using your hands directly on the speaker to avoid burns.
结论
Emma Lyman
于01/17/23注册
385 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 230
