跳转到主内容
Skullcandy Hesh 3 Battery Replacement
你所需要的
  1. Skullcandy Hesh 3 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Skullcandy Hesh 3 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Skullcandy Hesh 3 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Start by removing the earmuffs on the speaker side with the charging port. Gently pull from any point of the ear cushion, while also holding on to the base of the speaker.
    • Use a Phillips #00 screwdriver to remove all four 4.0 mm screws securing the faceplate.
    • Remove the faceplate gently without pulling off the wires attached to the speaker and faceplate.
  2. Skullcandy Hesh 3 Battery Replacement: 步骤 2 中的图像 1,3 Skullcandy Hesh 3 Battery Replacement: 步骤 2 中的图像 2,3 Skullcandy Hesh 3 Battery Replacement: 步骤 2 中的图像 3,3
    • Use a soldering iron to heat up the solder at the points where the red, yellow, and black wires connect until they detach from the board.
    • Lastly, lift the board gently from the ear cup to reveal the battery underneath.
  3. Skullcandy Hesh 3 Battery Replacement: 步骤 3 中的图像 1,3 Skullcandy Hesh 3 Battery Replacement: 步骤 3 中的图像 2,3 Skullcandy Hesh 3 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the battery being held by adhesive rubber with a spudger or your hands.
    • The battery should come out with minimal force as the adhesive is not very strong.
    • When replacing with the new battery, position it in the same spot with the 3 wires sticking out from the upper left-hand corner.
结论
Emma Lyman
于01/17/23注册
385 声望
创作了4篇指南
一条评论
Useful but doesn't mention battery type or where or if you can buy replacement battery.
John Layne - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 39
总计 693
