跳转到主内容
Skullcandy Crusher Wireless Headphone USB Connector Replacement
你所需要的
  1. Skullcandy Crusher Wireless Headphone USB Connector Replacement, Ear Cushion: 步骤 1 中的图像 1,2 Skullcandy Crusher Wireless Headphone USB Connector Replacement, Ear Cushion: 步骤 1 中的图像 2,2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 步骤 2 中的图像 1,2 Skullcandy Crusher Wireless Headphone USB Connector Replacement: 步骤 2 中的图像 2,2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 步骤 3 中的图像 1,1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Headphone USB Connector Replacement, USB Connector: 步骤 4 中的图像 1,2 Skullcandy Crusher Wireless Headphone USB Connector Replacement, USB Connector: 步骤 4 中的图像 2,2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion.
  5. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 步骤 5 中的图像 1,3 Skullcandy Crusher Wireless Headphone USB Connector Replacement: 步骤 5 中的图像 2,3 Skullcandy Crusher Wireless Headphone USB Connector Replacement: 步骤 5 中的图像 3,3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 步骤 6 中的图像 1,2 Skullcandy Crusher Wireless Headphone USB Connector Replacement: 步骤 6 中的图像 2,2
    • Separate the headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Headphone USB Connector Replacement: 步骤 7 中的图像 1,1
    • Inspect the USB port and ensure that it is connected correctly. If necessary, desolder the USB port and replace it with the new port.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
结论
Val
于03/31/22注册
1,104 声望
创作了6篇指南
团队
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 UMass Dartmouth, Team 1-33, Gurgel Spring 2022 的会员
UMASSD-GURGEL-S22S1G33
1 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 68
总计 1,069
