跳转到主内容
SkullCandy INK'D 2 Audio Jack Replacement
你所需要的
  1. SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: 步骤 1 中的图像 1,2 SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: 步骤 1 中的图像 2,2
    • Use wire cutters to remove the audio jack.
    • Use wire cutters to remove approximately 1/2 inch of insulation of the wire and separate the four wires inside of it.
    • Red wire is the right speaker '+' terminal.
    • Green wire is the left speaker '+' terminal.
    • Golden wire is the ground terminal.
    • Purple wire is the microphone terminal.
  2. SkullCandy INK'D 2 Audio Jack Replacement: 步骤 2 中的图像 1,1
    • Take the replacement connector and separate the wires on it.
    • Red wire is the right earphone.
    • Green wire is the left earphone.
    • Blue wire is the ground terminal.
    • Gold wire is the microphone.
  3. SkullCandy INK'D 2 Audio Jack Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Heat Shrink Tubing Assortment
    $7.99
    购买
    • Put shrink tubing on either one of the wires.
    • For each wire color, put the headphone wire and the replacement wire into clamps. Weave them together using fingers.
    • Review the soldering guide before initiating Step 4.
  4. SkullCandy INK'D 2 Audio Jack Replacement: 步骤 4 中的图像 1,1
    • Use soldering equipment to solder together two wires.
    • Repeat this step for each of the four wire colors.
    • Always wear safety glasses when soldering.
  5. SkullCandy INK'D 2 Audio Jack Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Digital Multimeter
    $19.99
    购买
    • Using Digital Multimeter in the "Continuity" mode, place two probes on the soldered wires of the same color. You will hear audio signal indicating that there is a connection.
    • Repeat this for each of the wire colors.
    • If there is no Multimeter signal, you will need to resolder the wires and to make sure that wires of different colors are completely separated.
  6. SkullCandy INK'D 2 Audio Jack Replacement: 步骤 6 中的图像 1,3 SkullCandy INK'D 2 Audio Jack Replacement: 步骤 6 中的图像 2,3 SkullCandy INK'D 2 Audio Jack Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    Heat Gun
    $24.99
    购买
    • After all wires are soldered, cover them with shrink tubing.
    • Use the heat gun to shrink the tubing and fit it tightly around the wires.
    • Gently apply heat in order to shape the tubing around the soldered wires.
结论
Repeat the procedure if you need to install a new audio jack.
Maksim Bondaruk
于10/16/17注册
119 声望
撰写一个指南
团队
Cal Poly, Team S4-G1, Livingston Fall 2017 Cal Poly, Team S4-G1, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G1
5 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 29
过去 30 天: 113
总计 15,512
