当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Protect your work area such as a desk with paper towels or newspaper.
Remove your bearings from your wheels, if they are not removed already. Please reference the Wheel Installation guide for information on how to properly remove bearings.
这个步骤还没有翻译 帮忙翻译一下
When finished scrubbing the bearing, rinse it in FRESH cleaning solution until there is no dirt or old lubricant in the bearings. Then set this bearing aside.
Repeat steps 4 - 7 for your remaining seven bearings. Be sure to continue to refresh your rinsing solution if it becomes too dirty.
这个步骤还没有翻译 帮忙翻译一下
Carefully wipe the bearing with a lint-free cloth that is slightly oily. After this you can replace the protective shield by simply pressing it into place.
Repeat steps 8 - 7 for all other bearings. After you have completely relubricated all of your bearings, see the Wheel Installation guide to help you install your bearings into your wheels.
2等其他人完成本指南。
