跳转到主内容
SiriusXM Onyx Plus Motherboard Replacement
你所需要的
  1. SiriusXM Onyx Plus Motherboard Replacement, Case: 步骤 1 中的图像 1,1
    • Wedge a plastic opening tool in between the case.
  2. SiriusXM Onyx Plus Motherboard Replacement: 步骤 2 中的图像 1,3 SiriusXM Onyx Plus Motherboard Replacement: 步骤 2 中的图像 2,3 SiriusXM Onyx Plus Motherboard Replacement: 步骤 2 中的图像 3,3
    • Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
    • You have to start with the bottom left and right corners, and then flip the device to over and do the top of the device.
  3. SiriusXM Onyx Plus Motherboard Replacement: 步骤 3 中的图像 1,1
    • Once unclipped, separate the back casing from the device.
  4. SiriusXM Onyx Plus Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 SiriusXM Onyx Plus Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove the three 5.4mm JIS #00 screws from the motherboard.
  5. SiriusXM Onyx Plus Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unlatch the two clips located at the top of the device that hold the motherboard in place.
  6. SiriusXM Onyx Plus Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift the motherboard up from the bottom.
  7. SiriusXM Onyx Plus Motherboard Replacement: 步骤 7 中的图像 1,1
    • Lift the screen up, so you can see where it is attached to the motherboard.
  8. SiriusXM Onyx Plus Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  9. SiriusXM Onyx Plus Motherboard Replacement: 步骤 9 中的图像 1,1
    • Carefully pull the ribbon out from the ZIF connector.
结论
Angel Rivera
于01/25/18注册
532 声望
创作了5篇指南
团队
USF Tampa, Team S7-G2, Passmore Spring 2018 USF Tampa, Team S7-G2, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 33
总计 1,806
