跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Sidekick II,应参考我们的维修指南
  1. Sidekick II Teardown, Outer Casing: 步骤 1 中的图像 1,1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Teardown: 步骤 2 中的图像 1,2 Sidekick II Teardown: 步骤 2 中的图像 2,2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Teardown: 步骤 3 中的图像 1,1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Teardown: 步骤 4 中的图像 1,1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Teardown: 步骤 5 中的图像 1,1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II Teardown, Sidekick II Teardown: 步骤 6 中的图像 1,2 Sidekick II Teardown, Sidekick II Teardown: 步骤 6 中的图像 2,2
    • Remove screen from casing.
  7. Sidekick II Teardown: 步骤 7 中的图像 1,2 Sidekick II Teardown: 步骤 7 中的图像 2,2
    • Remove 4 screws from back of screen using Torx 6 Screwdriver.
    • Pry screen out of casing using fingers.
  8. Sidekick II Teardown: 步骤 8 中的图像 1,3 Sidekick II Teardown: 步骤 8 中的图像 2,3 Sidekick II Teardown: 步骤 8 中的图像 3,3
    • Remove 4 screws from front of screen with Phillip screwdrivers.
    • Peel off the metal covering on the back of the screen.
    • Be careful when taking off the metal covering. The orange ribbon will not come out all the way, and it is fragile.
  9. Sidekick II Teardown: 步骤 9 中的图像 1,1
    • Remove the protective cover in front of the screen.
    • Do not use metal tools, you may damage the protective cover or the screen. Use your fingers only.
  10. Sidekick II Teardown: 步骤 10 中的图像 1,2 Sidekick II Teardown: 步骤 10 中的图像 2,2
    • Take the screws out using the Torx 6 screwdriver.
    • Then lift the thumb wheel and housing off of the front panel.
  11. Sidekick II Teardown: 步骤 11 中的图像 1,2 Sidekick II Teardown: 步骤 11 中的图像 2,2
    • Remove 2 black "rivets" from back of casing with the plastic opening tool.
    • Press keyboard out of front of casing using thumbs. Don't press too hard as you may break the board.
  12. Sidekick II Teardown: 步骤 12 中的图像 1,2 Sidekick II Teardown: 步骤 12 中的图像 2,2
    • Remove the 5 black screws with a Phillips head screwdriver.
    • Lift the bottom of the control board from housing, and separate the two.
  13. Sidekick II Teardown: 步骤 13 中的图像 1,1
    • Carefully remove battery and back plate.
    • Do not use metal tools, you may damage the control board. Use only your fingers.
  14. Sidekick II Teardown: 步骤 14 中的图像 1,1
    • Here are all of the pieces that you have disassembled
michael albaum
于01/20/10注册
87 声望
创作了6篇指南
团队
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010 的会员
CPSU-MANESS-W10S3G19
4 名成员
创作了11篇指南
1指南评论
nice job from a former geek
Jared Boies - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 81
总计 8,045
