跳转到主内容
Shark NV352 Roller Brush Motor Replacement
你所需要的
  1. Shark NV352 Roller Brush Motor Replacement, Roller Brush: 步骤 1 中的图像 1,2 Shark NV352 Roller Brush Motor Replacement, Roller Brush: 步骤 1 中的图像 2,2
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Roller Brush Motor Replacement: 步骤 2 中的图像 1,1
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Roller Brush Motor Replacement: 步骤 3 中的图像 1,2 Shark NV352 Roller Brush Motor Replacement: 步骤 3 中的图像 2,2
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Roller Brush Motor Replacement: 步骤 4 中的图像 1,2 Shark NV352 Roller Brush Motor Replacement: 步骤 4 中的图像 2,2
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Roller Brush Motor Replacement: 步骤 5 中的图像 1,2 Shark NV352 Roller Brush Motor Replacement: 步骤 5 中的图像 2,2
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Roller Brush Motor Replacement: 步骤 6 中的图像 1,2 Shark NV352 Roller Brush Motor Replacement: 步骤 6 中的图像 2,2
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Roller Brush Motor Replacement: 步骤 7 中的图像 1,1
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Roller Brush Motor Replacement: 步骤 8 中的图像 1,1
    • Take out the roller brush by lifting it out of its tray.
  9. Shark NV352 Roller Brush Motor Replacement, Roller Brush Motor: 步骤 9 中的图像 1,1
    • The wires are attached to the motor, so take out the motor slowly to ensure that they do not break.
    • Remove the roller brush motor by carefully lifting it out of the vacuum.
  10. Shark NV352 Roller Brush Motor Replacement: 步骤 10 中的图像 1,1
    • Desolder the wires running to the motor from the motherboard. For details on how to desolder, visit this soldering guide.
结论
3等其他人完成本指南。
Wesley T Benica
于09/22/17注册
378 声望
创作了2篇指南
团队
Cal Poly, Team S18-G5, Forte Fall 2017 Cal Poly, Team S18-G5, Forte Fall 2017 的会员
CPSU-FORTE-F17S18G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 53
总计 3,146
