跳转到主内容
Shark ION Robot R75 Side Brush Motor Replacement
你所需要的
  1. Shark ION Robot R75 Side Brush Motor Replacement, Battery: 步骤 1 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement, Battery: 步骤 1 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the robot is shut off by pressing the power button on top.
    • Flip the R75 over so that the underside is facing up.
    • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
    • Remove the battery cover.
  2. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 2 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 2 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 2 中的图像 3,3
    • Be careful when removing the battery, as it will still be connected to a wire.
    • Slowly pull the white tabs outward to remove the battery.
  3. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 3 中的图像 1,2 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 3 中的图像 2,2
    • Be careful when removing the connector, as the part can break if too much force is used.
    • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
    • Remove the battery from the device.
  4. Shark ION Robot R75 Side Brush Motor Replacement, Main Brush: 步骤 4 中的图像 1,1
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
  5. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 5 中的图像 1,1
    • Pull the main brush slightly to the right to remove it from the compartment.
  6. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 6 中的图像 1,2 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 6 中的图像 2,2
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
  7. Shark ION Robot R75 Side Brush Motor Replacement, Side Brush: 步骤 7 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement, Side Brush: 步骤 7 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement, Side Brush: 步骤 7 中的图像 3,3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
  8. Shark ION Robot R75 Side Brush Motor Replacement, Drive Wheel Assembly: 步骤 8 中的图像 1,1
    • Flip the R75 to its underside.
    • Make sure the R75 is shut off.
    • For extra security, disconnect the battery by following the prerequisite guide.
  9. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 9 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 9 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 9 中的图像 3,3
    • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
    • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
    • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
  10. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 10 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 10 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 10 中的图像 3,3
    • Flip the wheel assembly over and disconnect the cable connector on its underside.
    • Remove the drive wheel assembly.
    • Repeat this process for the other side if necessary.
  11. Shark ION Robot R75 Side Brush Motor Replacement, Shark ION Robot R75 Caster Wheel: 步骤 11 中的图像 1,1
    • Orient the device with the bottom facing up.
  12. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 12 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 12 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 12 中的图像 3,3
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
  13. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 13 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 13 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 13 中的图像 3,3
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
  14. Shark ION Robot R75 Side Brush Motor Replacement, Top Cover: 步骤 14 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement, Top Cover: 步骤 14 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement, Top Cover: 步骤 14 中的图像 3,3
    • Push down on the black tab and remove the dust bin
  15. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 15 中的图像 1,2 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 15 中的图像 2,2
    • Using a Torx TR15 screwdriver, remove the five screws from the bottom cover.
  16. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 16 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 16 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 16 中的图像 3,3
    • Make sure the robot is facing rearward
    • Using a Torx TR15 screwdriver, remove the five screws along the front edge of the device.
    • Pull the bottom part of the bump guard away from the body of the device.
  17. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 17 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 17 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 17 中的图像 3,3
    • Lift the top cover up from the rear of the robot to separate the top cover from the rest of the robot.
    • Be careful when separating the top from the rest of the robot, as the plastic clips can break if excessive force is applied.
    • From here, easy access to all sensors, the main brush motor, and the fan are all granted.
  18. Shark ION Robot R75 Side Brush Motor Replacement, Side Sensor: 步骤 18 中的图像 1,2 Shark ION Robot R75 Side Brush Motor Replacement, Side Sensor: 步骤 18 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the screw holding down the diagonally vented side cover.
    • Slide the sensor out from the base of the robot
  19. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 19 中的图像 1,2 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 19 中的图像 2,2
    • Lift up the diagonally vented cover on the side of the robot containing the side sensor.
  20. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 20 中的图像 1,2 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 20 中的图像 2,2
    • Disconnect the white connector from the sensor.
  21. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 21 中的图像 1,2 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 21 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the screw on the sensor.
    • Remove the sensor from its mount.
  22. Shark ION Robot R75 Side Brush Motor Replacement, Side Brush Motor: 步骤 22 中的图像 1,2 Shark ION Robot R75 Side Brush Motor Replacement, Side Brush Motor: 步骤 22 中的图像 2,2
    • Make sure that both the left and right side sensors have been removed from their compartments.
    • Using a Phillips #0 screwdriver, remove the two screws on either side of the motherboard.
  23. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 23 中的图像 1,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 23 中的图像 2,3 Shark ION Robot R75 Side Brush Motor Replacement: 步骤 23 中的图像 3,3
    • Place your fingers in the groove right above the bump sensor.
    • Carefully lift the motherboard and plastic assembly up to expose the motors and charging contacts.
  24. Shark ION Robot R75 Side Brush Motor Replacement: 步骤 24 中的图像 1,1
    • Lift the malfunctioning motor from its slot in the device.
    • Desolder the two connections on the faulty motor.
    • If you're unfamiliar with soldering techniques and best practices, check out our How to Solder and Desolder Connections guide!
结论
4等其他人完成本指南。
5条评论
What is the motor part that is being replaced?
Cheryl Bobo - 回复
I have a different question.
My ion 75 will clean for three minutes, and then it returns to dock. I have cleaned everything underneath but have not unscrewed anything. Popped the wheels and brushes and used Qtip on the side sensors. I charged directly from the wall (bypassing the charger) and had the same result….. three minutes cleaning and returns to dock.
Am I being premature to suspect a battery replacement is needed? This detailed article of yours has me wondering.
flea
Gail Burgess - 回复
My ion RV870 series just stopped working flashes blue max. I have checked all components and cleaned. It has a good charge. I see no dysfunction what so ever. How do I get it working again?? I'm out of ideas because everything seems to be functional and clean.
Gina Madore - 回复
These were awesome instructions for me. Mine had hair wrapped around the brush motor spindle. Before fix it would come off the dock and stop after like 1 foot. After tear down and full clean, it went over an hour. Thank you!
Naz Lazar - 回复
I have the Shark IQ, this was very similar and absolutely awesome. Thanks so much
Lance Plummer - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 140
总计 7,941
