跳转到主内容
Shark Flex DuoClean Power Cord Replacement
你所需要的
  1. Shark Flex DuoClean Power Cord Replacement, Dust Cup: 步骤 1 中的图像 1,2 Shark Flex DuoClean Power Cord Replacement, Dust Cup: 步骤 1 中的图像 2,2
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Power Cord Replacement, Power Cord: 步骤 2 中的图像 1,2 Shark Flex DuoClean Power Cord Replacement, Power Cord: 步骤 2 中的图像 2,2
    • Remove the pre-motor filter with your hands.
  3. Shark Flex DuoClean Power Cord Replacement: 步骤 3 中的图像 1,1
    • Remove the post-motor filter.
  4. Shark Flex DuoClean Power Cord Replacement: 步骤 4 中的图像 1,1
    • Remove the two 15 mm screws by twisting counterclockwise with the T10 Torx screwdriver.
  5. Shark Flex DuoClean Power Cord Replacement: 步骤 5 中的图像 1,2 Shark Flex DuoClean Power Cord Replacement: 步骤 5 中的图像 2,2
    • Remove the two 12 mm screws by twisting counterclockwise with the T15 Torx screwdriver.
    • To fully remove the power cord, cut the wires using a wire cutter.
    • For reassembly, use the soldering guide in the Introduction.
结论
2等其他人完成本指南。
caoimhe
于10/08/18注册
979 声望
创作了4篇指南
团队
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 的会员
CPSU-WHITE-F18S17G5
4 名成员
创作了14篇指南
一条评论
I found with further dissasembly, uncrimping and recrimping the wiring loom saved having to add more connections.
qwazew - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,376
