跳转到主内容
Shark Flex DuoClean LED Headlight Replacement
你所需要的
  1. Shark Flex DuoClean LED Headlight Replacement, Garage Door: 步骤 1 中的图像 1,2 Shark Flex DuoClean LED Headlight Replacement, Garage Door: 步骤 1 中的图像 2,2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean LED Headlight Replacement, Side Component: 步骤 2 中的图像 1,2 Shark Flex DuoClean LED Headlight Replacement, Side Component: 步骤 2 中的图像 2,2
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean LED Headlight Replacement: 步骤 3 中的图像 1,2 Shark Flex DuoClean LED Headlight Replacement: 步骤 3 中的图像 2,2
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean LED Headlight Replacement: 步骤 4 中的图像 1,1
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean LED Headlight Replacement: 步骤 5 中的图像 1,1
    • Remove the side component with your hands.
  6. Shark Flex DuoClean LED Headlight Replacement, LED Headlight: 步骤 6 中的图像 1,1
  7. Shark Flex DuoClean LED Headlight Replacement: 步骤 7 中的图像 1,2 Shark Flex DuoClean LED Headlight Replacement: 步骤 7 中的图像 2,2
    • Use the nylon spudger to pry the gold, plastic cover off of the headlights.
    • Prying off the cover too aggressively may cause it to break.
  8. Shark Flex DuoClean LED Headlight Replacement: 步骤 8 中的图像 1,2 Shark Flex DuoClean LED Headlight Replacement: 步骤 8 中的图像 2,2
  9. Shark Flex DuoClean LED Headlight Replacement: 步骤 9 中的图像 1,2 Shark Flex DuoClean LED Headlight Replacement: 步骤 9 中的图像 2,2
    • Use the metal spudger to pry off the clear, plastic cover on the LEDs.
    • Prying the cover off too aggressively may cause it to break.
  10. Shark Flex DuoClean LED Headlight Replacement: 步骤 10 中的图像 1,1
    • Use wire cutters to detach the black cables from the LEDs on both sides.
    • Strip 1 cm off the ends of the wires, using a wire stripper.
    • Solder the exposed wires to the new LEDs.
    • Use the soldering guide in the Introduction.
结论
团队
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 的会员
CPSU-WHITE-F18S17G5
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,608
