跳转到主内容
Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement
你所需要的
  1. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement, External Pieces: 步骤 1 中的图像 1,3 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement, External Pieces: 步骤 1 中的图像 2,3 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement, External Pieces: 步骤 1 中的图像 3,3
    • Press the Hose Release button and pull back to detach the hose.
  2. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 2 中的图像 1,2 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 2 中的图像 2,2
    • Press the Wand Release button and pull up on the metal tube to remove the entire hose.
  3. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 3 中的图像 1,2 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 3 中的图像 2,2
    • Press the Lift Away button and pull up on the handle to separate the top of the vacuum from the bottom.
  4. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 4 中的图像 1,2 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 4 中的图像 2,2
    • Pull up on the extra brush pieces to remove them from the vacuum.
  5. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement, Filter: 步骤 5 中的图像 1,3 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement, Filter: 步骤 5 中的图像 2,3 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement, Filter: 步骤 5 中的图像 3,3
    • Pull up on the Dustbin Release button, and pull up on the handle to detach the dustbin.
  6. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 6 中的图像 1,1
    • Pull up on the filter tab to remove the large foam filter.
  7. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 7 中的图像 1,1
    • Pull up on the small tab to remove the filter pad.
  8. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement, Power Cable/Connector: 步骤 8 中的图像 1,2 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement, Power Cable/Connector: 步骤 8 中的图像 2,2
    • Use the T20 screwdriver to remove the two 12 mm screws by turning counterclockwise.
    • Use the T20 screwdriver to remove the two 17 mm screws by turning counterclockwise.
    • Use the T20 screwdriver to remove the two 14 mm screws by turning counterclockwise.
  9. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 9 中的图像 1,2 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 9 中的图像 2,2
    • Use the T20 screwdriver to remove the three 15 mm screws by turning counterclockwise.
    • Use the T10 screwdriver to remove the one 17 mm screw by turning counterclockwise.
  10. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 10 中的图像 1,2 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 10 中的图像 2,2
    • Use the T20 screwdriver to remove the four 14 mm screws from the bottom of the vacuum by turning counterclockwise.
    • The grey plastic cylinders will detach.
  11. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 11 中的图像 1,2 Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 11 中的图像 2,2
    • Use the metal spudger to pry off the back panel.
    • Be careful not to break or snap any plastic.
  12. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 12 中的图像 1,1
    • On the white cap holding the wire, use the T20 screwdriver to remove the two 12 mm screws by turning counter-clockwise .
    • Remove the white cap by pulling it off the device.
  13. Shark DuoClean Powered Lift-Away Speed Power Cable/Connector Replacement: 步骤 13 中的图像 1,1
    • Use wire cutters to detach the power cord by cutting the black and white wires.
    • For reassembly, you must strip and then rewire the new power cord using wire strippers and end caps. Use this guide to learn more about stripping wires.
结论
To reassemble your device, you must rewire a new power cord, then follow these instructions in reverse order.
6等其他人完成本指南。
团队
Cal Poly, Team S17-G4, White Fall 2018 Cal Poly, Team S17-G4, White Fall 2018 的会员
CPSU-WHITE-F18S17G4
4 名成员
创作了16篇指南
2条评论
Very well done. You need a few stars,/.
David Nancoo - 回复
Where to buy replacement power cord? Looks like it needs 120V, 60 Hz, 1150W, 9.5 A, but when I search for those parameters nothing comes up. Best way to search for replacement?
Erika Racherbaumer - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 33
过去 30 天: 155
总计 20,475
