跳转到主内容
加入维修社区 - 创建账户
Sewing a Curved Seam
你所需要的
  1. Sewing a Curved Seam, Sewing a Curved Seam: 步骤 1 中的图像 1,2 Sewing a Curved Seam, Sewing a Curved Seam: 步骤 1 中的图像 2,2
    • Lay the two pieces of fabric with the right sides together.
    • Align the edges you would like to sew. Push out all the wrinkles and smooth the fabric flat.
    询问修复机器人
    添加评论
  2. Sewing a Curved Seam: 步骤 2 中的图像 1,3 Sewing a Curved Seam: 步骤 2 中的图像 2,3 Sewing a Curved Seam: 步骤 2 中的图像 3,3
    • Starting at one end of the seam, match the corners and pin them together.
    • Work your way down the edge to be sewn, pinning the two pieces of fabric together.
    • The closer the pins are, the more stable their hold will be. However, you will have to stop to remove each pin as you sew. For a beginner's skill level, space the pins an inch or two apart.
    • Continue until you've pinned the two pieces of fabric from corner to corner.
    询问修复机器人
    添加评论
  3. Sewing a Curved Seam: 步骤 3 中的图像 1,3 Sewing a Curved Seam: 步骤 3 中的图像 2,3 Sewing a Curved Seam: 步骤 3 中的图像 3,3
    • Align the edge of the fabric with the edge of the presser foot, then depress the presser foot.
    • Engage the sewing machine's backstitch function.
    • Backstitch functions vary widely between machines and can come in the form of buttons, levers, and knobs. See your sewing machine manual for instructions on your backstitch function.
    • Depress the pedal slowly. Sew two or three stitches backwards. Release the pedal and disengage the backstitch function.
    询问修复机器人
    添加评论
  4. Sewing a Curved Seam: 步骤 4 中的图像 1,3 Sewing a Curved Seam: 步骤 4 中的图像 2,3 Sewing a Curved Seam: 步骤 4 中的图像 3,3
    • Depress the pedal and sew slowly forward, guiding the fabric with your hands as you go.
    • When guiding the fabric through a sewing machine you should not be pushing or pulling. The machine will feed the fabric in at the right speed. Your job is merely to guide the fabric so the seam remains straight.
    • Keep the fabric aligned to the edge of the presser foot as you sew.
    • Stop before you reach each pin. Pull the pins out, being careful not to misalign the fabric.
    询问修复机器人
    添加评论
  5. Sewing a Curved Seam: 步骤 5 中的图像 1,3 Sewing a Curved Seam: 步骤 5 中的图像 2,3 Sewing a Curved Seam: 步骤 5 中的图像 3,3
    • Continue to sew along the curved edge.
    • Pull out the last pin and sew up to the fabric's end.
    • When you come to the end of your seam, engage the backstitch function. Sew two or three stitches backwards. Release the backstitch function and sew forward off the fabric.
    • Turn the balance wheel until the needle is up.
    • Lift the presser foot up and clip the threads holding the fabric to the machine as close to the fabric as possible.
    询问修复机器人
    添加评论
  6. Sewing a Curved Seam: 步骤 6 中的图像 1,2 Sewing a Curved Seam: 步骤 6 中的图像 2,2
    • Lay out the newly sewn fabric on your work surface.
    • With a pair of fabric scissors, make a series of cuts about 1 cm apart into the raw edge of the seam until the fabric begins to curve. This will ensure that the seam lays flat.
    • Do not cut the seam itself, or you will have to resew the section.
    询问修复机器人
    添加评论
  7. Sewing a Curved Seam: 步骤 7 中的图像 1,3 Sewing a Curved Seam: 步骤 7 中的图像 2,3 Sewing a Curved Seam: 步骤 7 中的图像 3,3
    • Once the edge of the fabric begins to curve, begin cutting small triangles about every inch along the edge with the point facing towards the seam.
    • The more triangles you cut, the smoother your seam will lay.
    • Continue cutting small triangles along the length of the fabric.
    • As with the beginning, you may simply cut slits into the straight sections, while curved edges require triangles.
    询问修复机器人
    添加评论
  8. Sewing a Curved Seam: 步骤 8 中的图像 1,2 Sewing a Curved Seam: 步骤 8 中的图像 2,2
    • Once you have cut triangles all along the seam, turn the fabric inside out so that the seam is now on the inside.
    • As you turn the fabric inside out, adjust the fabric at the raw edge of the seam to get the smoothest seam possible.
    • Once your fabric is inside-out and your seam is flat, stand back and admire your beautiful handiwork.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
90,988 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了31,622篇指南
2指南评论
How do you sew seamed curves by hand? Also, how do you seam a circle by hand? I'm sorry to ask I just don't have a sewing machine and I wanted to create something before next Saturday.
Ataliaha Blake - 回复 分享
TBH but you simply do not need to worry about this because with that limited resources and knowledge provided by essaywriters no one will be able to craft such a masterpiece like embroidery patches that match out of that and it's almost here.
Albert Silva - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 80
总计 19,338
