跳转到主内容
加入维修社区 - 创建账户
Set-Top Box Numb Button Replacement
你所需要的
  1. Set-Top Box Numb Button Replacement, Numb Button: 步骤 1 中的图像 1,3 Set-Top Box Numb Button Replacement, Numb Button: 步骤 1 中的图像 2,3 Set-Top Box Numb Button Replacement, Numb Button: 步骤 1 中的图像 3,3
    • Make sure the box is not plugged in before starting!
    • Remove the 5 screws holding the outer casing in place: 3 can be found on the back and 1 on either side of the box.
    • Slide the casing backwards.
  2. Set-Top Box Numb Button Replacement: 步骤 2 中的图像 1,3 Set-Top Box Numb Button Replacement: 步骤 2 中的图像 2,3 Set-Top Box Numb Button Replacement: 步骤 2 中的图像 3,3
    • Disconnect the front of the by lifting the 2 connectors . You can also apply extra pressure on the front from below.
    • Tilt the front forward and remove it.
    • Remove the connector by pressing the upper part of it and carefully pulling it.
    • Be carefull not to damage the cables and circuit board!
  3. Set-Top Box Numb Button Replacement: 步骤 3 中的图像 1,3 Set-Top Box Numb Button Replacement: 步骤 3 中的图像 2,3 Set-Top Box Numb Button Replacement: 步骤 3 中的图像 3,3
    • Undo the 4 screws of the front panel.
    • Locate your broken button. For instance, the third button from the left (front view), is the CH- button.
  4. Set-Top Box Numb Button Replacement: 步骤 4 中的图像 1,3 Set-Top Box Numb Button Replacement: 步骤 4 中的图像 2,3 Set-Top Box Numb Button Replacement: 步骤 4 中的图像 3,3
    • Unsolder the push button. You can push it out or maybe use some plyers.
    • Remove the old button and insert the new one.
    • Solder the new push button on.
    • Check this link for help 如何焊接和拆焊
结论
Yvo Kipping
于12/05/16注册
101 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 613
