跳转到主内容
Sennheiser HD 4.50 Battery Replacement
你所需要的
  1. Sennheiser HD 4.50 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the side designation on the headband-earpiece junction.
    • The battery is on the left side.
    • The motherboard is on the right side.
  2. Sennheiser HD 4.50 Battery Replacement: 步骤 2 中的图像 1,3 Sennheiser HD 4.50 Battery Replacement: 步骤 2 中的图像 2,3 Sennheiser HD 4.50 Battery Replacement: 步骤 2 中的图像 3,3
  3. Sennheiser HD 4.50 Battery Replacement: 步骤 3 中的图像 1,3 Sennheiser HD 4.50 Battery Replacement: 步骤 3 中的图像 2,3 Sennheiser HD 4.50 Battery Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry open the cover.
    • Remove the cover.
  4. Sennheiser HD 4.50 Battery Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to pry the battery from the plastic case.
    • The battery is held down by a strong adhesive, so it will give resistance.
  5. Sennheiser HD 4.50 Battery Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, pull the white battery connector upwards out of its socket.
    • Remove the battery.
结论
7等其他人完成本指南。
6条评论
Hello ! Thanks for the tuto. Do you know where to buy the battery ?
Fren6 - 回复
You can search with the part number(Shown in the photo) : AHB622540N1/AHB622540N01.
Santanu Ghosal - 回复
Where i can find it
Erik Ridwan -
Does anyone know if I can use the he 450 bt replacement battery in a 350 bt headphone? The difference in the spec is that the 450’s battery has a longer battery life (2.2 wh vs. 1.3 wh)
M Lawson - 回复
This was pretty straightforward, but in opening the cap one of the tiny soldered wires pulled off the pad. It's so tiny that I don't have much hope of soldering it back. Any other way to reattach it? I put it back together anyways and now the right cup works fine, but the left is dead. I recommend a warning here about the little wires, if nothing else.
David Hook - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 88
过去 30 天: 553
总计 12,859
