跳转到主内容
加入维修社区 - 创建账户
Screen Replacement For Samsung Note 20 Ultra
你所需要的
视频概述
  1. Screen Replacement For Samsung Note 20 Ultra, Identify the problem: 步骤 1 中的图像 1,2 Screen Replacement For Samsung Note 20 Ultra, Identify the problem: 步骤 1 中的图像 2,2
    • On this Note 20 the OLED is clearly broken and has a crack on the side.
    • The back has no damage to it so apply heat.
    • Apply Heat to back glass
    • I do not have a picture of my heating process I hope you have a heat gun I use a crock pot with rubber in it.
  2. Screen Replacement For Samsung Note 20 Ultra, Prep for back glass removal: 步骤 2 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra, Prep for back glass removal: 步骤 2 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra, Prep for back glass removal: 步骤 2 中的图像 3,3
    • Be sure the back glass is too hot to touch!!
    • I prep my ifixit splicer with 99% alcohol to help losen adhesive.
    • Start from the bottom straight up and down push tool in until you hit the frame you will hear a sound
    • Slide tool at angle stop at the curve
  3. Screen Replacement For Samsung Note 20 Ultra, Back Glass Removal: 步骤 3 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra, Back Glass Removal: 步骤 3 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra, Back Glass Removal: 步骤 3 中的图像 3,3
    • After loosening the bottom pull tool out.
    • Heat is Applied
    • Now pry with your fingers and pull up with suction cup.
    • While sticking splicer on curved edge side slowly working wiggling down the curve edge
    • Lift and wiggle the back glass off
  4. Screen Replacement For Samsung Note 20 Ultra, Remove Sim/Stylus: 步骤 4 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra, Remove Sim/Stylus: 步骤 4 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra, Remove Sim/Stylus: 步骤 4 中的图像 3,3
    • We did it no cracks! High Five Youself
    • Remove Sim Card
    • Remove stylus
  5. Screen Replacement For Samsung Note 20 Ultra, Wireless Charging Coil: 步骤 5 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra, Wireless Charging Coil: 步骤 5 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra, Wireless Charging Coil: 步骤 5 中的图像 3,3
    • Remove 6 PH000 Screws from the wireless charging pad covering the battery connection.
    • Disconnect wireless coil from connections with plastic spudger
    • Use spudger at top on the metal squeezing it under the top of the wireless charging pad bracket.
    • Lift and wiggle slowly the charging pad off while locating the battery connection
    • Battery Connection!!
  6. Screen Replacement For Samsung Note 20 Ultra, Disconnect Battery: 步骤 6 中的图像 1,1
    • Disconnect the battery with spudger!
  7. Screen Replacement For Samsung Note 20 Ultra, Ear Speaker Bracket: 步骤 7 中的图像 1,1
    • Remove 4 PH000 Screws to the ear speaker bracket.
    • Also disconnect this connection!
    • Please comment is this a proximity senor?
  8. Screen Replacement For Samsung Note 20 Ultra, Mainboard: 步骤 8 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra, Mainboard: 步骤 8 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra, Mainboard: 步骤 8 中的图像 3,3
    • The battery should already be disconnected!
    • Use a spudger
    • Make sure its disconnected
    • Disconnect all yellow boxed connections!
    • Remove the 2 PH000 Screws holding the camera
    • Lift mainboard with spudger from ear speaker goin down using the frame as a leveler
    • With all the connection the board may snag on the connections be slow and observer feel for tension.
  9. Screen Replacement For Samsung Note 20 Ultra, Front Camera: 步骤 9 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra, Front Camera: 步骤 9 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra, Front Camera: 步骤 9 中的图像 3,3
    • Front Camera do not break it is serialized to the phone! Can't be repaired if is broken!
    • Front Camera Location
    • Use heat or 99% alcohol to get it removed
    • Use straight edge blade at bottom of camera to break it loose. You can actually pull the glue/adhesive out it will come out in one chunk.
    • Lift camera out slowly
  10. Screen Replacement For Samsung Note 20 Ultra: 步骤 10 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 10 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 10 中的图像 3,3
    • Remove 5 PH000 Screws for the Loudspeaker bracket
    • Use spudger to lift out bracket
    • Disconnect flex cables
    • Remove 3 Black PH000 Screws to microphoned board and charger port
  11. Screen Replacement For Samsung Note 20 Ultra: 步骤 11 中的图像 1,2 Screen Replacement For Samsung Note 20 Ultra: 步骤 11 中的图像 2,2
    • Lift out Microphone board 1st
    • Then lift out charge port wiggling it loose
    • Good lift spot with point end of spudger at arrow location
    • Loosen Adhesive
  12. Screen Replacement For Samsung Note 20 Ultra, Small Parts: 步骤 12 中的图像 1,2 Screen Replacement For Samsung Note 20 Ultra, Small Parts: 步骤 12 中的图像 2,2
    • Remove 2 black PH000 Screws on top right lifting flex out.
    • Remove 2 PH000 Screws on Bottom right lift flex out.
    • Use heat it has adhesive holding it down.
    • The top right flex can disconnect from connection not sure 100% what all these parts do yet.
  13. Screen Replacement For Samsung Note 20 Ultra: 步骤 13 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 13 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 13 中的图像 3,3
    • Suction Cup, Green Plastic Spudger, and Alcohol to get it out.
    • Spray with alcohol start a little pry to get alcohol under battery
    • Lift with suction cup on battery
    • Bam its out not damaged
  14. Screen Replacement For Samsung Note 20 Ultra: 步骤 14 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 14 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 14 中的图像 3,3
    • Move back all small parts into new frame screen assembly
    • Vibator
    • Frame Flex Cables
    • Charge Port goes in 1st
    • Then microphone board goes on top of charge port. Connect the flex cables
    • 3 Black PH000 Screws
  15. Screen Replacement For Samsung Note 20 Ultra: 步骤 15 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 15 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 15 中的图像 3,3
    • Lay the main board down in new frame
    • Insert the front camera after laying the board down
  16. Screen Replacement For Samsung Note 20 Ultra: 步骤 16 中的图像 1,2 Screen Replacement For Samsung Note 20 Ultra: 步骤 16 中的图像 2,2
    • Lay out adhesive for under the battery
    • Connect the battery 1st then lay it on adhesive
    • Disconnect battery
    • Connect al loose flex cables to there connections
  17. Screen Replacement For Samsung Note 20 Ultra: 步骤 17 中的图像 1,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 17 中的图像 2,3 Screen Replacement For Samsung Note 20 Ultra: 步骤 17 中的图像 3,3
    • Screw brackets down and wireless charge pad to test phone before putting it fully together
    • Apply adhesive to back of phone lay back glass back down
    • If you have to replace back glass you have to move microphone from old back glass rear camera lens to the new back glass.
  18. Screen Replacement For Samsung Note 20 Ultra: 步骤 18 中的图像 1,2 Screen Replacement For Samsung Note 20 Ultra: 步骤 18 中的图像 2,2
    • I use liquid adhesive to hold the back glass down
    • Clamp the back down for a couple hours
    • We are done!
    • Did not have to replace back glass on this one :)
    • Replaced back glass on this one and added a fun twist of my face.
    • To remove back glass paint use acetone and blade to pull paint off.
结论
During this repair on the black Note 20 Ultra I noticed the screen looked refurbished had issues with screws being stripped I did some serious work drilling into the phone. Which is not included in this guide.
Before I worked on the phone that had the stripping screw issue I already had worked on the phone which I made a video and had not issues with screws stripping the phone I did the picture guide was clearly refurbished straight talk phone.
16等其他人完成本指南。
Mark D Schlossman
于09/25/19注册
7,164 声望
创作了9篇指南
9指南评论
I did the repair and ran into issues with the REAR camera. I retraced all my hardware. its all connected. the selfie cam works. nothing got disconnected when I removed the mother board. i’ve tried to reset app cache
help plz
Abe Arslan - 回复
Do you have all the screws back in with the speakers and wireless charger coil on the phone?
Stow -
Rear camera hmm did you try repeating the connection did the cameras work before repair?
Mark D Schlossman -
Thanks for the effort here with the guide. Unless I am missing something (lol) where is the part of the screen replacement (by screen = the display screen, right?) I see the back replacement here. You do mention the OLED screen being broken at the beginning but the guide is for the back replacement, right? (not as title suggests ‘screen replacement) Sorry maybe am wrong here.
s ner - 回复
He transfered anything from the original phone to the new sreen/frame assembly.
Daniele Carminati -
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 73
过去 30 天: 339
总计 27,542
