当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
In the compartment, move the small notch and push down on the battery to remove it.
During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
Using the spudger, gently pry the rear panel away from the left side.
Be careful not to damage the three green cables as you remove the rear panel of the camera.
Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
Do not put any excessive force on the green wires.
Separate the rear panel from the rest of the camera.
Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
Carefully pull off the side covers wrapped around the camera.
Using the spudger, gently lift off the front cover of the camera.
The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
Use caution not to damage ribbon when disconnecting.
The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
Remove the two screws holding the photo array.
Remove the foam from the top of the wire connector.
Gently remove the plastic connector in the same way as the previous connector of the same type.
Lift the connector from the side with the ribbon cable in it.
Using the spudger, gently push from the right side.
取消:我没有完成这个指南。
与7其他贡献者
于04/11/10注册
26 声望
创作了4篇指南
徽章: 5
+ 2更多徽章
CPSU-AMIDO-S10S27G95
4 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 10
总计 2,084
