跳转到主内容
Sanyo VPC-T850 Photo Array Device Replacement
你所需要的
  1. Sanyo VPC-T850 Photo Array Device Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 2 中的图像 1,1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 3 中的图像 1,1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 4 中的图像 1,1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 Photo Array Device Replacement, Outer Casing: 步骤 5 中的图像 1,3 Sanyo VPC-T850 Photo Array Device Replacement, Outer Casing: 步骤 5 中的图像 2,3 Sanyo VPC-T850 Photo Array Device Replacement, Outer Casing: 步骤 5 中的图像 3,3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 6 中的图像 1,2 Sanyo VPC-T850 Photo Array Device Replacement: 步骤 6 中的图像 2,2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 7 中的图像 1,1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 8 中的图像 1,2 Sanyo VPC-T850 Photo Array Device Replacement: 步骤 8 中的图像 2,2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 9 中的图像 1,1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
  10. Sanyo VPC-T850 Photo Array Device Replacement, LCD Display: 步骤 10 中的图像 1,1
    • Flip the device over to where the display is located.
    • Using your plastic opening tool, lift the display out of its metal housing.
  11. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 11 中的图像 1,1
    • Locate the orange ribbon connecting the display to the camera.
    • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
  12. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 12 中的图像 1,1
    • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
    • Pull slowly to avoid severing the orange ribbon from the display.
  13. Sanyo VPC-T850 Photo Array Device Replacement, Photo Array Device: 步骤 13 中的图像 1,1
    • Remove the two screws holding the photo array.
  14. Sanyo VPC-T850 Photo Array Device Replacement: 步骤 14 中的图像 1,3 Sanyo VPC-T850 Photo Array Device Replacement: 步骤 14 中的图像 2,3 Sanyo VPC-T850 Photo Array Device Replacement: 步骤 14 中的图像 3,3
    • Remove the foam from the top of the wire connector.
    • Gently remove the plastic connector in the same way as the previous connector of the same type.
    • Lift the connector from the side with the ribbon cable in it.
    • Using the spudger, gently push from the right side.
结论
Jonathan Yau
于04/11/10注册
26 声望
创作了4篇指南
团队
Cal Poly, Team 27-95, Amido Spring 2010 Cal Poly, Team 27-95, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G95
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 2,216
