跳转到主内容
Samsung SmartThings Hub Power Port Replacement
你所需要的
  1. Samsung SmartThings Hub Power Port  Replacement, Power Port: 步骤 1 中的图像 1,1
    • To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
  2. Samsung SmartThings Hub Power Port  Replacement: 步骤 2 中的图像 1,3 Samsung SmartThings Hub Power Port  Replacement: 步骤 2 中的图像 2,3 Samsung SmartThings Hub Power Port  Replacement: 步骤 2 中的图像 3,3
    • Make sure the batteries are removed before attempting disassembly.
    • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
    • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
  3. Samsung SmartThings Hub Power Port  Replacement: 步骤 3 中的图像 1,3 Samsung SmartThings Hub Power Port  Replacement: 步骤 3 中的图像 2,3 Samsung SmartThings Hub Power Port  Replacement: 步骤 3 中的图像 3,3
    • Once all five screws are removed, split the casing apart by applying gentle upwards pressure against the positive terminals in the battery compartment.
  4. Samsung SmartThings Hub Power Port  Replacement: 步骤 4 中的图像 1,2 Samsung SmartThings Hub Power Port  Replacement: 步骤 4 中的图像 2,2
    • To remove the motherboard, grip the USB port and the Ethernet port. Lift up, then slide towards the front of the device to release the motherboard from the black retaining clip shown on the right.
  5. Samsung SmartThings Hub Power Port  Replacement: 步骤 5 中的图像 1,3 Samsung SmartThings Hub Power Port  Replacement: 步骤 5 中的图像 2,3 Samsung SmartThings Hub Power Port  Replacement: 步骤 5 中的图像 3,3
    • Place the motherboard on a clean, flat surface.
    • Preheat your soldering iron. The power port has three points of connection to the motherboard (pictured below). Using your soldering iron, apply heat to each solder joint in turn while pulling the power port away from the board.
    • Soldering irons can reach temperatures of over 500 degrees. Watch your fingers!
    • For more information on soldering refer to How to Solder and Desolder Connections
  6. Samsung SmartThings Hub Power Port  Replacement: 步骤 6 中的图像 1,2 Samsung SmartThings Hub Power Port  Replacement: 步骤 6 中的图像 2,2
    • Using tweezers, remove the desoldered power port from the motherboard.
结论
5等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,227
