跳转到主内容
Samsung Series 5 Ultrabook Speakers Replacement
你所需要的
  1. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Screws on the Back Cover: 步骤 1 中的图像 1,2 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Screws on the Back Cover: 步骤 1 中的图像 2,2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Rubber Pads: 步骤 2 中的图像 1,2 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Rubber Pads: 步骤 2 中的图像 2,2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Back Cover: 步骤 3 中的图像 1,2 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Back Cover: 步骤 3 中的图像 2,2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 Ultrabook Speakers Replacement: 步骤 4 中的图像 1,2 Samsung Series 5 Ultrabook Speakers Replacement: 步骤 4 中的图像 2,2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 Ultrabook Speakers Replacement: 步骤 5 中的图像 1,1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Battery: 步骤 6 中的图像 1,1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 Ultrabook Speakers Replacement: 步骤 7 中的图像 1,1
    • Remove the battery from the laptop.
结论
Javier Jimenez
于11/04/19注册
223 声望
创作了2篇指南
团队
IUPUI, Team S1-G6, Harley Fall 2019 IUPUI, Team S1-G6, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S1G6
3 名成员
创作了2篇指南
一条评论
And about removing speakers?
Rodrigo Melo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 727
