跳转到主内容
Samsung Series 5 UltraTouch Battery Replacement
你所需要的
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: 步骤 1 中的图像 1,2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: 步骤 1 中的图像 2,2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: 步骤 2 中的图像 1,2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: 步骤 2 中的图像 2,2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: 步骤 3 中的图像 1,2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: 步骤 3 中的图像 2,2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: 步骤 4 中的图像 1,2 Samsung Series 5 UltraTouch Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: 步骤 6 中的图像 1,1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the battery from the laptop.
结论
14等其他人完成本指南。
Timothy
于01/30/15注册
1,579 声望
创作了5篇指南
团队
USF Tampa, Team 16-3, Watkins Winter 2015 USF Tampa, Team 16-3, Watkins Winter 2015 的会员
USFT-WATKINS-W15S16G3
4 名成员
创作了5篇指南
2条评论
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - 回复
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 42
总计 26,902
