跳转到主内容
Samsung Refrigerator Evaporator Drain Clip Replacement
你所需要的
  1. Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: 步骤 1 中的图像 1,3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: 步骤 1 中的图像 2,3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: 步骤 1 中的图像 3,3
    • Using a spudger, pry off the cap covering the topmost screw.
  2. Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 2 中的图像 1,3 Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 2 中的图像 2,3 Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 2 中的图像 3,3
    • Remove three 12.7 mm screws using a Phillips #0 screwdriver.
  3. Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 3 中的图像 1,3 Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 3 中的图像 2,3 Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 3 中的图像 3,3
    • Use your hands or a spudger to pry back the plastic cover starting from the bottom.
    • Once all the clips are pulled out, loosen the cover by pushing it slightly up and out.
    • Do not pull the cover off yet; there are still connectors attaching the cover to the fridge.
  4. Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 4 中的图像 1,3 Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 4 中的图像 2,3 Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 4 中的图像 3,3
    • Gently unplug both connectors.
    • Remember their orientations as it will be important during reassembly.
  5. Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 5 中的图像 1,1
    • Using a hair dryer or heat gun, melt down any ice buildup in the draining well.
  6. Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 6 中的图像 1,1
    • Cut out the old evaporating clip using a pair of cutting pliers.
  7. Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 7 中的图像 1,3 Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 7 中的图像 2,3 Samsung Refrigerator Evaporator Drain Clip Replacement: 步骤 7 中的图像 3,3
    • Replace the old clip with a new evaporating clip.
结论
8等其他人完成本指南。
Deep Patel
于09/15/20注册
320 声望
撰写一个指南
团队
3条评论
Problem only resolved for about 6 months post clip replacement. Now every 2 months back to defrosting my refrigerator, under the crisper drawer. Now the entire section of the drain is frozen. Very frustraing.
David Kahan - 回复
Here's another video of this replacement. Head over to the refrigerator leaking water wiki for more fixes for freezing lines.
nicO - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 57
过去 30 天: 194
总计 18,278
