跳转到主内容
Samsung RC512 Screen Replacement
你所需要的
  1. Samsung RC512 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the laptop upside down.
  2. Samsung RC512 Screen Replacement: 步骤 2 中的图像 1,2 Samsung RC512 Screen Replacement: 步骤 2 中的图像 2,2
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Screen Replacement, Screen: 步骤 3 中的图像 1,3 Samsung RC512 Screen Replacement, Screen: 步骤 3 中的图像 2,3 Samsung RC512 Screen Replacement, Screen: 步骤 3 中的图像 3,3
    • The Laptop should be off before removing the battery.
  4. Samsung RC512 Screen Replacement: 步骤 4 中的图像 1,3 Samsung RC512 Screen Replacement: 步骤 4 中的图像 2,3 Samsung RC512 Screen Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the gray covers with tweezers to expose the 4mm screws.
    • Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
  5. Samsung RC512 Screen Replacement: 步骤 5 中的图像 1,2 Samsung RC512 Screen Replacement: 步骤 5 中的图像 2,2
    • Insert the blue plastic opening tool into the bezel and rear housing of the screen.
    • Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Work your way around the sides carefully and continue this to the bottom.
    • You may use your fingers to help remove the cover.
  6. Samsung RC512 Screen Replacement: 步骤 6 中的图像 1,2 Samsung RC512 Screen Replacement: 步骤 6 中的图像 2,2
    • With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
    • As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
  7. Samsung RC512 Screen Replacement: 步骤 7 中的图像 1,3 Samsung RC512 Screen Replacement: 步骤 7 中的图像 2,3 Samsung RC512 Screen Replacement: 步骤 7 中的图像 3,3
    • Gently lay the LCD onto the keyboard.
    • Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together.
    • Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Grasp the video connector at its base and pull it away from the LCD screen.
    • The only thing holding the screen will be the clear tape causing it to come out easily.
结论
另外一个人完成了本指南。
jando
于09/15/16注册
896 声望
创作了8篇指南
团队
USF Tampa, Team 18-2, Blackwell Fall 2016 USF Tampa, Team 18-2, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 702
