跳转到主内容
加入维修社区 - 创建账户
Samsung P241 Power Cable Replacement
你所需要的
  1. Samsung P241 Power Cable Replacement, Top Case: 步骤 1 中的图像 1,2 Samsung P241 Power Cable Replacement, Top Case: 步骤 1 中的图像 2,2
    • You will need to be near a power source for this guide.
    • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  2. Samsung P241 Power Cable Replacement: 步骤 2 中的图像 1,2 Samsung P241 Power Cable Replacement: 步骤 2 中的图像 2,2
    • Pull the top cover towards you until you can lift it up and off.
    询问修复机器人
    添加评论
  3. Samsung P241 Power Cable Replacement, Power Cable: 步骤 3 中的图像 1,2 Samsung P241 Power Cable Replacement, Power Cable: 步骤 3 中的图像 2,2
    • Unclip the power cable from the motherboard and gently pull up to remove.
    询问修复机器人
    添加评论
  4. Samsung P241 Power Cable Replacement: 步骤 4 中的图像 1,2 Samsung P241 Power Cable Replacement: 步骤 4 中的图像 2,2
    • Once you have unclipped the power cable, use a multimeter (left) to test if the cable is still functional.
    • Turn the dial on the multimeter to continuity test mode.
    • Make sure the positive lead is plugged into the voltmeter/ohmeter outlet.
    询问修复机器人
    添加评论
  5. Samsung P241 Power Cable Replacement: 步骤 5 中的图像 1,2 Samsung P241 Power Cable Replacement: 步骤 5 中的图像 2,2
    • Use one multimeter lead to touch one of the prongs on the AC side of power cable. Use the other lead to touch one end of the clip side of the power cable.
    • The multimeter will show numbers if there is a good electrical connection. If it does not show any numbers the first time, try using the lead to touch the other prong.
    • Repeat the above directions with the other prong and clip side of the power cable.
    • If the multimeter does not show numbers during any of the connections, your power cable is dead and you will need to replace it.
    询问修复机器人
    添加评论
  6. Samsung P241 Power Cable Replacement: 步骤 6 中的图像 1,1
    • If you found that the power cable has a good electrical connection, you will have to test that the cable has not shorted out.
    • To do this, touch each prong on the AC side of the power cable. If numbers show on the screen, your power cable is bad and must be replaced.
    • If your power cable is bad, do not replug the cable into the AC outlet.
    • If the cable works, the problem is with the motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 14-7, Forte Winter 2011 Cal Poly, Team 14-7, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G7
5 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 30
总计 1,591
