跳转到主内容
加入维修社区 - 创建账户
Samsung P241 Motherboard Replacement
你所需要的
    1. Samsung P241 Motherboard Replacement, Top Case: 步骤 1 中的图像 1,2 Samsung P241 Motherboard Replacement, Top Case: 步骤 1 中的图像 2,2
      • You will need to be near a power source for this guide.
      • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. Samsung P241 Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung P241 Motherboard Replacement: 步骤 2 中的图像 2,2
      • Pull the top cover towards you until you can lift it up and off.
      询问修复机器人
      添加评论
    1. Samsung P241 Motherboard Replacement, Front Panel: 步骤 3 中的图像 1,2 Samsung P241 Motherboard Replacement, Front Panel: 步骤 3 中的图像 2,2
      • With the front of the DVD player facing you, turn the power on and eject the disc tray.
      • Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover. The cover should easily pop up and off the disc tray.
      • Be careful not to crack or bend the disc tray by pulling too hard.
      询问修复机器人
      添加评论
    2. Samsung P241 Motherboard Replacement: 步骤 4 中的图像 1,3 Samsung P241 Motherboard Replacement: 步骤 4 中的图像 2,3 Samsung P241 Motherboard Replacement: 步骤 4 中的图像 3,3
      • To remove the front panel, lift up the clips on the bottom, left and right sides of the DVD player.
      • Be sure to have all clips lifted up at the same time otherwise it will be difficult to get the panel off.
      • If you are having trouble removing the panel, try wedging an object underneath the two clips on the bottom to keep them from falling back into place.
      询问修复机器人
      添加评论
    3. Samsung P241 Motherboard Replacement: 步骤 5 中的图像 1,1
      • Gently remove the front panel by pulling it forward.
      询问修复机器人
      添加评论
    4. Samsung P241 Motherboard Replacement: 步骤 6 中的图像 1,1
      • Press the eject button again to make the disc tray slide back into place.
      • Turn off the DVD player and unplug it from the wall before proceeding to further steps.
      询问修复机器人
      添加评论
    1. Samsung P241 Motherboard Replacement, Main Board: 步骤 7 中的图像 1,3 Samsung P241 Motherboard Replacement, Main Board: 步骤 7 中的图像 2,3 Samsung P241 Motherboard Replacement, Main Board: 步骤 7 中的图像 3,3
      • Take out the two ribbon cables adjacent to the DVD drive and the power supply in the upper left hand corner of the board (with the DVD drive oriented on the right) before attempting to remove the main board.
      询问修复机器人
      添加评论
    2. Samsung P241 Motherboard Replacement: 步骤 8 中的图像 1,1
      • Remove each of the four 0.6 cm brass screws with a Phillips #2 screwdriver near the corners of the main board indicated by the red circles.
      • Be sure to keep your screws in a safe place to prevent losing them.
      询问修复机器人
      添加评论
    3. Samsung P241 Motherboard Replacement: 步骤 9 中的图像 1,3 Samsung P241 Motherboard Replacement: 步骤 9 中的图像 2,3 Samsung P241 Motherboard Replacement: 步骤 9 中的图像 3,3
      • After all four screws have been completely removed, use a pair of pliers to push the two tabs of both white push fasteners located off-center left and indicated by the red circles.
      • Now that the tabs are depressed, carefully lift the main board from it's position in the case. While sliding the main board up, be mindful to pull the video and audio out ports away from the rear of the case.
      询问修复机器人
      添加评论
    4. Samsung P241 Motherboard Replacement: 步骤 10 中的图像 1,1
      • Remember to dispose of your damaged main board correctly by taking it to your nearest recycling center.
      • Now replace the void in your DVD case with the functional main board.
      • REMINDER: Be attentive to the audio and video out ports as you set the new main board in it's place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
John Warren
于01/13/11注册
129 声望
撰写一个指南
团队
Cal Poly, Team 14-7, Forte Winter 2011 Cal Poly, Team 14-7, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G7
5 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 32
总计 3,282
