跳转到主内容
Samsung NX3000 LCD Replacement
你所需要的
  1. Samsung NX3000 LCD Replacement, Battery: 步骤 1 中的图像 1,3 Samsung NX3000 LCD Replacement, Battery: 步骤 1 中的图像 2,3 Samsung NX3000 LCD Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn the camera upside down. Only remove the lens if you have to in order to access the battery compartment, as dust particles could easily enter the main body and fall onto the delicate sensor.
    • Slide the button to the left to open the battery compartment.
    • Push the blue button up to release the battery.
    • The battery is not shown in these photos.
  2. Samsung NX3000 LCD Replacement, Lens Assembly: 步骤 2 中的图像 1,2 Samsung NX3000 LCD Replacement, Lens Assembly: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the four 7.3 mm Phillips screws from the front of the lens assembly.
    • Remove the silver ring with tweezers.
  3. Samsung NX3000 LCD Replacement: 步骤 3 中的图像 1,2 Samsung NX3000 LCD Replacement: 步骤 3 中的图像 2,2
    • Use tweezers to remove the black plastic ring and small metal ring inside the lens assembly.
  4. Samsung NX3000 LCD Replacement: 步骤 4 中的图像 1,3 Samsung NX3000 LCD Replacement: 步骤 4 中的图像 2,3 Samsung NX3000 LCD Replacement: 步骤 4 中的图像 3,3
    • Use tweezers to lift the pyramid screw and spring from the lens assembly.
  5. Samsung NX3000 LCD Replacement, Back Case: 步骤 5 中的图像 1,2 Samsung NX3000 LCD Replacement, Back Case: 步骤 5 中的图像 2,2
    • Remove the three 4.3 mm Phillips screws from the bottom of the camera.
    • Remove the 4.3 mm Phillips screw hiding inside the battery compartment.
  6. Samsung NX3000 LCD Replacement: 步骤 6 中的图像 1,2 Samsung NX3000 LCD Replacement: 步骤 6 中的图像 2,2
    • Remove the 4.2 mm Phillips screw from the left handgrip.
    • Remove the two 4.2 mm Phillips screws from the right handgrip.
  7. Samsung NX3000 LCD Replacement: 步骤 7 中的图像 1,2 Samsung NX3000 LCD Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the metal shield from the external flash mount.
  8. Samsung NX3000 LCD Replacement: 步骤 8 中的图像 1,1
    • Remove the four 5 mm Phillips screws from the external flash mount .
  9. Samsung NX3000 LCD Replacement: 步骤 9 中的图像 1,2 Samsung NX3000 LCD Replacement: 步骤 9 中的图像 2,2
    • Remove the external flash mount.
  10. Samsung NX3000 LCD Replacement: 步骤 10 中的图像 1,2 Samsung NX3000 LCD Replacement: 步骤 10 中的图像 2,2
    • Slowly pull the bottom of the back case away from the camera.
    • Do not attempt to remove the back case as it is attached to the motherboard by a ribbon cable.
  11. Samsung NX3000 LCD Replacement: 步骤 11 中的图像 1,3 Samsung NX3000 LCD Replacement: 步骤 11 中的图像 2,3 Samsung NX3000 LCD Replacement: 步骤 11 中的图像 3,3
    • Use the flat end of a spudger to pry the flat topped connector straight up from the motherboard.
    • Remove the back case.
  12. Samsung NX3000 LCD Replacement, LCD: 步骤 12 中的图像 1,3 Samsung NX3000 LCD Replacement, LCD: 步骤 12 中的图像 2,3 Samsung NX3000 LCD Replacement, LCD: 步骤 12 中的图像 3,3
    • To remove the metal shield on the back case, remove the following screws:
    • Five black 4.2 mm Phillips screws .
    • Four silver 5.3 mm Phillips screws.
  13. Samsung NX3000 LCD Replacement: 步骤 13 中的图像 1,3 Samsung NX3000 LCD Replacement: 步骤 13 中的图像 2,3 Samsung NX3000 LCD Replacement: 步骤 13 中的图像 3,3
    • Insert the pointed end of a spudger into the whole on the ribbon cable holding the button panel to the back case.
    • Remove the button panel.
  14. Samsung NX3000 LCD Replacement: 步骤 14 中的图像 1,2 Samsung NX3000 LCD Replacement: 步骤 14 中的图像 2,2
    • Use a spudger to peel back the LCD ribbon from the back case.
    • The ribbon is held in place by adhesive.
  15. Samsung NX3000 LCD Replacement: 步骤 15 中的图像 1,2 Samsung NX3000 LCD Replacement: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the plastic cover on the LCD hinge.
  16. Samsung NX3000 LCD Replacement: 步骤 16 中的图像 1,2 Samsung NX3000 LCD Replacement: 步骤 16 中的图像 2,2
    • Tilt the LCD so it lays flat against the back case.
    • Wiggle the LCD joints and pull the LCD away from the back case.
结论
2等其他人完成本指南。
Kelsea Weber
于11/12/15注册
21,027 声望
创作了32篇指南
1指南评论
Hello, Any Idea how to reset firmware after update did not succeed. Service manual for NX300 gives some glue but how about NX3000? Wherefrom to get the needed software pieces
Raimo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,434
