跳转到主内容
Samsung NP900X4B Wifi Card Replacement
你所需要的
  1. Samsung NP900X4B Wifi Card Replacement, Wifi Card: 步骤 1 中的图像 1,1
    • This guide should be attempted after the removal of the back panel is completed.
    • The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
  2. Samsung NP900X4B Wifi Card Replacement: 步骤 2 中的图像 1,1
    • In order to continue, you need to observe the inside of the laptop and find where the Wifi Card is located.
  3. Samsung NP900X4B Wifi Card Replacement: 步骤 3 中的图像 1,1
    • After finding the Wifi Card, you will discover two more 2.5mm Phillips #00 screws which hold the card in place.
    • The screws locations are shown in the image.
    • The same bit piece will be used to unscrew these (PH00/PH000). After completing this continue to the next step.
  4. Samsung NP900X4B Wifi Card Replacement: 步骤 4 中的图像 1,2 Samsung NP900X4B Wifi Card Replacement: 步骤 4 中的图像 2,2
    • There will be two wires connecting to the Wifi Card from the laptop.
    • These wires can be removed with one of the plastic tools in the iFixit toolkit by applying slight force onto them.
    • After removing the wires move on to the next step.
  5. Samsung NP900X4B Wifi Card Replacement: 步骤 5 中的图像 1,2 Samsung NP900X4B Wifi Card Replacement: 步骤 5 中的图像 2,2
    • This last step is the easiest of them all, all you need to do it pick up the Wifi Card from its position and you're done!
    • Now you are able to replace the card by following these steps in reverse or have the card further repaired.
结论
Jacob Drohan
于10/15/18注册
121 声望
撰写一个指南
团队
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 UMass Dartmouth, Team S4-G6, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S4G6
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 221
