跳转到主内容
Samsung NP900X4B Battery Replacement
你所需要的
  1. Samsung NP900X4B Battery Replacement, Battery: 步骤 1 中的图像 1,2 Samsung NP900X4B Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung NP900X4B Battery Replacement: 步骤 2 中的图像 1,1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung NP900X4B Battery Replacement: 步骤 3 中的图像 1,2 Samsung NP900X4B Battery Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung NP900X4B Battery Replacement: 步骤 4 中的图像 1,1
    • Lift and pull out the battery.
结论
Nathan LeBlanc
于10/17/18注册
109 声望
撰写一个指南
团队
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 UMass Dartmouth, Team S4-G6, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S4G6
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 643
