本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove the outer casing of your device.
你所需要的
Pull the release tab away from the battery.
Slide the battery towards the release tab and then pull the battery away from the camcorder.
Rotate the camcorder so that the strap side is facing you.
Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
即将完成!
结论
另外一个人完成了本指南。
