当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Pull the release tab away from the battery.
Slide the battery towards the release tab and then pull the battery away from the camcorder.
Rotate the camcorder so that the strap side is facing you.
Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
Rotate the camcorder so that the battery slot is facing you.
Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
Rotate the camcorder so you are looking at the bottom of the camcorder.
Locate and remove the last three 4.5mm Phillips #00 screws.
With both hands, pull the side strap apart from the rest of the camcorder.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与3其他贡献者
于09/26/17注册
705 声望
创作了6篇指南
徽章: 12
+ 9更多徽章
USFT-BOCZAR-F17S13G1
4 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 307
